Results 1 to 11 of 11
    Jan 2019
    Default 2020 Prius Prime
    2020 Prius Prime
    89170-47810
    R7F701A223
    NEED A CLEAR FILE.
    THANK YOU!
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by rovmak View Post
    2020 Prius Prime
    89170-47810
    R7F701A223
    NEED A CLEAR FILE.
    THANK YOU!
    Test and report...........
    Feb 2016
    Могу ли я получить пароль? С моим блоком после чистки B1163 Может не правильно прочитал. Благодарю вас! VVDI-прог.
    Feb 2016
    Могу ли я получить пароль? С моим блоком после шины B1163. Может не правильно прочитал. Благодарю вас! VVDI-prog
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by byvitali View Post
    what is your srs module number?
    Feb 2016
    89170-47810 Toyota Prius 2020
    Feb 2016
    This is what it was before cleaning.
    superjet's Avatar
    Aug 2018
    Your clear file.
    report.no report no help next...
    pass in your pm.
    Feb 2016
    Same problem! B1163. Maybe a hardware problem? I use vvdi-prog
    superjet's Avatar
    Aug 2018
    This is tested file,report
    same pass
    Feb 2016
    B1163 remained! All systems fired up
