Results 1 to 10 of 10
    Jan 2012
    Default 906 sprinter dashboard virginize Help!
    how can i virginize this file? can someone pls help ??
    ecu:25LC640
    Thanks in advance
  2. The Following User Says Thank You to asfalt For This Useful Post:
    zieroy (15th October, 2022)
  3. #2
    levisdj's Avatar
    EcuLand
    no need, just sync dash to ezs
    Jan 2012
    but the dash is replaced
    Jan 2012
    how can i sync dash to ezs
    Jan 2012
    i cant see the kilometer on dashboard
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    I think xentry helps you
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    just swap eeprom from old to new
  9. The Following User Says Thank You to jomberykaso For This Useful Post:
    MileageAudit5 (2nd February, 2024)
  10. #8
    Jun 2016
    or rewrite SSID from EZS
  11. #9
    Dec 2020
    Where is the SSID stored in dash? Unfortunately I do not have someone around with AVDI or similar to sync dash to EZS... I need SSID from dump "old" in dump "new". Its a 2011 VW Crafter, I swapped from lowline to highline dash.
  12. #10
    Jan 2017
    Netherlands
    AVDI won't always help you, just did a W212 dash swap and also got the 'already connected to other car' message in both autel and xentry (had someone try online) as a fault code. AVDI gives option to sync used dash to EZS but only thing it did is zero the odometer and giving error that connecting failed.. no help from there on . On bench did put in correct mileage again (already did before putting in the cluster due to risque of increasing EZS mileage if cluster was higher on replacing) but still only get stripes on odometer . Only when turning off the car and removing key the EZS goes to sleep and instrument cluster will still show the correct and updated mileage for a few secs before going dark... not to fancy . I read somewhere you can connect cluster with Vediamo, but right now my Xentry system is braking down (just booted up first time new year and Xentry comes with 'unregistered' message, even after redoing a new start key session... Chinese crap)...
