Are you really sure about this? I mean the content is installed locally on the computer and should be available without internet connection to the JD site. There must be an opportunity to crack the SW security even if it was built to check access rights every time the program is started. The question should be more if someone has had the effort?
Do you mean you got it up and running too or are you just saying thanks for the DVDs that nobody seems to be able to run (at least not a single person confirming a successful installation so far)? Of course the files are a good start but everyone would prefer to get further than downloading the files.
thank you to all
someone has tried with vmware or cracklock?
any other links
this one is dead
thank you ,i need service advisor too
i need service advisor too thanks in advance
I explained this in another thread: I was able to install the SW with a 30 day trial period (should work later if the computer clock is adjusted, I have not tried this yet). I had two issues, one was the SQL2005 server that I managed to install separately. Another problem seemed to be that the SW did not accept SP3 XP, I had to install a SP2 version of XP first.
i try installation procedure for jhon deere...thanks
hello everyone. i registered just for this. i "Could Possibly" have a copy of the Setup CD and Agrucultural (sorry about bad spelling) disks and SQL files and The prereq files. BUT the only problem is the time stamp on the disks and i "may" be having troubles changing the time stamps and getting it to work. i say possibly and may as im being very sensitive around this matter. if you think you are skillfull enough to get it to work personal message me
