Results 1 to 15 of 20
    Jul 2020
    Default code from volvo SC-811
    Hi! I need help to find a code from radio SC-811. I read the eeprom X24C01, but i can´t find the code. Anybody can help me
    shooting's Avatar
    WALES
    Quote Originally Posted by Mulinari View Post
    It's a bad read because you are using a programmer NOT compatible with this chip, buy a better programmer...
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  3. The Following User Says Thank You to shooting For This Useful Post:
    Decode Ghost (9th July, 2020)
    Jul 2020
    [QUOTE = shooting; 3909908] É uma leitura ruim porque você está usando um programador que NÃO é compatível com este chip. Compre um programador melhor ...
    wbr [/ QUOTE]
    Thanks for answer! How programmer do you suggest? Ponyprog works?
    Bulgaria
    Dump must look like this:
    You can use any programmer that support X24c01. Like SeeProg (by ELNEC), PonyProg, TinyProg, ... Many brands/models.
    wbr [/ QUOTE]
    If I help you, just press Thanks and Reputation
  6. The Following User Says Thank You to svetlim For This Useful Post:
    shooting's Avatar
    WALES
    wbr [/ QUOTE]
    Search for TL866A .. it's cheap and reads these...
    wbr
  8. The Following User Says Thank You to shooting For This Useful Post:
  9. #6
    Jul 2020
    I got a new reading with a friend, in another programmer and software. This reading is attached. If not, is it possible to obtain this code through the serial number label? Follow: B04842739IMG-20200709-WA0036.jpg
  10. #7
    carradio2001's Avatar
    France
    try 1635. Good luck. Carradio2001.
  11. The Following 4 Users Say Thank You to carradio2001 For This Useful Post:
    cheero (9th July, 2020), Decode Ghost (9th July, 2020), masterskay62 (9th July, 2020), svetlim (9th July, 2020)
  12. #8
    May 2018
    try code 1635 ............
  13. The Following 3 Users Say Thank You to treran21 For This Useful Post:
  14. #9
    Jul 2020
    It worked!!! Thank you very much !!!
  15. The Following User Says Thank You to Mulinari For This Useful Post:
  16. #10
    Aug 2023
    Quote Originally Posted by carradio2001 View Post
    Hello. Hope you are doing fine.
    Can you please help me too with code?
    B40733685
    Thanks.
  17. #11
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by DraGro View Post
    B40733685
    Thanks.
    Read and apply the above not possible with serial number!!!!!!
  18. The Following User Says Thank You to Decode Ghost For This Useful Post:
    DraGro (19th August, 2023)
  19. #12
    Aug 2023
    If i unerstand correctly i have to provide you with dump photo like above..?
    Thank you
  20. #13
    Aug 2015
    Thank you
    NO! This is what you want to read the eprom chip that contains the code of the device!!!!!!!
    it is to go to your nearest local decoder, pay for it and get the code. Don't bother!!!
  21. The Following User Says Thank You to Decode Ghost For This Useful Post:
  22. #14
    Aug 2023
    So. I must read the eprom with apropriate programmer and there will be the code presented in regular numbers, right?
    Thanks.
  23. #15
    Aug 2015
    Thanks.
    yes, Encrypted software was used so that it wouldn't break the device for novices like you!!!!!
  24. The Following User Says Thank You to Decode Ghost For This Useful Post:
