Results 1 to 4 of 4
    Nov 2020
    Default Revelprog IS Programmer wiring diagram for SOIC clip to read/write 93c56/66 chips
    Hi I have a Revelprog IS programmer and was hoping not to have to desolder the 93c56 and 66 chips so I can program them in place using the SOIC clip.
    Does anybody have the wiring sequence for the harness which attaches to the SOIC clip as cannot read the chips in place, or is it possible to actually program these chips in series without removing them. Toyota models mostly Alphard and Vellfire.
    Any Help appreciated
    Jardel's Avatar
    Jun 2020
    Brazil
    I don't know this programmer, but to read the circuit you would need to decrease the voltage. Does it have this feature? And as for the pinout, if it's an adapter cable you can figure out the sequence yourself with a multimeter.
  3. The Following User Says Thank You to Jardel For This Useful Post:
    buds (25th November, 2020)
    Nov 2018
    Hello i use this programmer i have the same problem in 93..86 Try without 6 pin : https://www.youtube.com/watch?v=bl2FaM1SxK4 and use vpp to 3,3V
  5. The Following User Says Thank You to Jasko93 For This Useful Post:
  6. #4
    Nov 2020
    Quote Originally Posted by Jardel View Post
    Hi Thanks yes have tried reducing voltage and dozens of wiring combinations on a removed chip but just will not read it. In the unit it reads perfectly.
