Results 1 to 13 of 13
    Apr 2019
    Guatemala
    Default Hilux 2018 C66 Timing Belt turn on
    hi there, i have a problem with a hilux 2.5 2018, the problem is that i had edit the dashboard, my archive is correct but, now when i putted back the eprom c66, my dashboard does't work in ODO, and the led of timing belt was turn on, someone have idea of whathappened?
    i will grateful if someone can help me
    Dec 2010
    Write back the original file...
  3. The Following User Says Thank You to junmab For This Useful Post:
    Motocriss (14th April, 2021)
    Apr 2019
    Guatemala
    i did it, and i try with other dump, and the cluster doesn't run
    Dec 2010
    OK .
    Let me understand your problem:
    The odometer shows but does not run.
    The tripmeter runs as usuall.
    The speedometer runs as usual.
    The BELT light is now on.
    It is well known problem with Yazaki dashboards that the odometer is not counting after altering the km.
    Please send a pictures of the face of the cluster and the label with the the part number.
    Please note: if you wrote back the original file but changed the km on it then this may be your problem. You have to write back the full original file untouched !
  6. The Following User Says Thank You to junmab For This Useful Post:
    Apr 2019
    Guatemala
    Quote Originally Posted by junmab View Post
    OK .
    Hello my dear friend how are you, check this photos you described my problem perfectly, the cluster's trip is working but the ODO doesn't have lecture, the T-BELT light is now on, the RPM and KM/H, Fuel level and temperature level doesn't move, just the ilumination and display is working i had reprogramming using the original file but the problem continues,
  8. #6
    Apr 2019
    Guatemala
  9. #7
    Dec 2010
    You should check the soldering, the print and the small resistors near the chip. You must check that there is nothing that might shorten the pins of the 9386.
    The problem you described is maybe because the mcu can not read the data from the 9386, therfore non of the gages are working.
  10. The Following User Says Thank You to junmab For This Useful Post:
    Motocriss (29th December, 2020)
  11. #8
    brend's Avatar
    Oct 2015
    Same where
    Without a dump, this problem can be discussed forever.
    Maybe Mr.Motocriss ​start thread with both dump ori and modified!
  12. The Following User Says Thank You to brend For This Useful Post:
  13. #9
    Dec 2010
    I think he's got an hardware problem. He should inspect carefully the pcb.
    If he would add the label with the part number, we could also locate an original dump for him.
  14. The Following User Says Thank You to junmab For This Useful Post:
    Motocriss (6th January, 2021)
  15. #10
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default 93c66 msop dump hilux gd-6
    try this dump ....
    'If I helped, please click Thanks +Reputation.. !'
  16. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
  17. #11
    Dec 2010
    Motocriss, use the dump that rtbdiagnostic gave you without altering for new km. Just write it as it is and check if everything came back.
    If everything will work well then you may alter the km.
  18. The Following User Says Thank You to junmab For This Useful Post:
  19. #12
    Apr 2019
    Guatemala
    Hello my dear friends, i repaired it, using the dump of rtbdiagnostic thank you so much, thanks to all memembers that was help me; i think that the original file was wrong when i read it, and i saved the modification in wrong mode
  20. #13
    Dec 2010
    Thank you for reporting.
    You should press the Thank you button for each of the members who have tried to help you.
  21. The Following 2 Users Say Thank You to junmab For This Useful Post:
    Motocriss (14th April, 2021), rtbdiagnostic (7th January, 2021)
