WOULD ANYONE HAVE A WIRING DIAGRAM FOR THE VAUXHALL FRONTERA B 2001 MODEL..ECU DIAGRAM
PLEASE.THANKS
PLEASE.THANKS
Normally never had problems with the spill valve ..
Check all connector plugs on these vehicles first for hot connections ... This will be spill valve connector and another plug close to top ecu ...
If no problem on these then check bottom EDU unit for dry joint first ...
Here a bench test
Must draw at least 4 amps (I use spill valve these days)
Dinero84 (23rd October, 2023), Dr Alex (10th November, 2019), martinracing (15th July, 2020), mexanico1971 (27th June, 2016), milenski70 (21st May, 2018), morfej (7th June, 2017), Radic8R (29th August, 2017)
Hello, I have the same problem -12v is missing, where is created these -12v tension in these ecu?
Hi friends,
I have the same problem with -12V (all -12V not only one in attachment), but I suspect that were marked by mistake - it should be 0V.
Could someone confirm it?
ecufix (2nd April, 2021)
thanx for know how, i have blowed regulator, capacitor, bad solder joints, repaired and working like new
Yeah it is quite funny
hi
3385 = 74hc04 3384 = 74hc02 3382 = 74hc08
ali kaptan (16th August, 2022), Dinero84 (23rd October, 2023), ecufix (3rd April, 2019), javierfichera (29th August, 2019), maucontacto (23rd May, 2017), mexanico1971 (29th August, 2016), milenski70 (21st May, 2018), olecram (19th December, 2017), PierreTheron (27th February, 2016), RadovanPetkovic (28th November, 2021), taxo1965 (4th April, 2017)
hi
-12v is 0v /car ground/ ecu case
mexanico1971 (30th June, 2016)
aititstu ; are you sure about these 3 ics? did you make a test with these? working? order that you describe it is ok?
thank you
yes, tryed working
Dinero84 (23rd October, 2023), marius7592 (28th November, 2020), maucontacto (23rd May, 2017), olecram (19th December, 2017), PierreTheron (9th March, 2016), taxo1965 (4th April, 2017)
Can You Believe
This is good thread
Be carefull for having burnt joints and then you try to solder it ..................... .
The unit might work for a day or a week and then bite you in the ass again ... (only for a simple dry joint ....
Hi Never had this component down yet ..
