Page 15 of 17 FirstFirst ... 51011121314151617 LastLast
Results 211 to 225 of 253
  1. #211
    Apr 2010
    belgrade,serbia
    stamanek ,you have to bring generator signal from UPA programer and put home bulb 220v
  2. #212
    Jan 2017
    i have a signal generator, what kind of signal and frequency does it need ?
  3. #213
    Aug 2016
    Hello, i am working on one unit that suddenly stopped working. No crack solders , it was repaired 2-3years ago. I checked voltages and i got 160-170v. Only voltage that is problematic is 8v. IT has only 6.5. Nothing is getting hot and consumption is 160ma when powered. Should i change 7808 or it can be something else?
  4. #214
    Mar 2016
    EU
    Please finally solve the transistor 9732 I R 704K, BUZ 91 does not work. Thank you.
  5. #215
    Feb 2010
    ...IRF640...
  6. The Following User Says Thank You to stas12 For This Useful Post:
    zzivo (4th January, 2019)
  7. #216
    Aug 2016
    Hello, i am working on 1 unit that makes me problem. I changes 9v regulator and all was working. Today customer calls me and told me car cuts. Car cutted suddenly on bump. Car then start and cuts after 10 sec work. I opened edu again and all voltages are spot on. 9v 12v 170v. Where should i continue looking for the problem?
  8. #217
    alldecode's Avatar
    Jan 2010
    EU, Croatia
    unsolder all pins, and disconect board from camatitors and coil
    put picture, and i show what need to soldering
    regards
  9. #218
    Aug 2016
    Hello, from last time i have 2 more with this same problem. I desolder the board, check all the solders and do resoldering. Check transistors, condensators, diodes all ok. I change stabiliser with 7809. Car works for anywhere from 20sec to 2 min and dies. I can pay for the solution of this problem...
  10. #219
    Mar 2013
    Just solved one yesterday with this symptoms ,culprit was bad contact inside connector of spill valve .
  11. #220
    Aug 2016
    Well i have cleaned the contacs and still the same. I make bench test with signal generator and light bulb... and the bulb is lighted and working. I leave bench test for 5 mins and no problem,, but when i put to car works 20 sec and shut down. I have 2 units and they have same problem, so must be something inside edu.
  12. #221
    Jan 2017
    Hello Guys, I have a problem with one of these EDU, Can someone explain where the 12V from pin 4 goes to next? If I connect 12V in Pin 4 nothing happens, but if I feed 12V in the 1500uF capacitor I have all the voltages, 170V on spill Valve and 8.6V on the regulator.
  13. #222
    mexanico1971's Avatar
    portugal
    Quote Originally Posted by digitalol View Post
    The circuits of the PCB are bad , that why car shot down after some time !
    Or wires in wire-loom are black and make resistance and EDU circuits get hot .
    I have here more than 10 width the same problem
    Brs
    My work is my life ART TECH GARAGE
  14. The Following User Says Thank You to mexanico1971 For This Useful Post:
    PierreTheron (22nd January, 2020)
  15. #223
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    buz91 also found buz31 inside..
  16. #224
    Sep 2009
    I have problem with EDU
    Disassembled, pcb removed, checked all solder, repair bad solder. Looks like all components good
    Tried on bench with 60W bulb and 2kHz input, all voltages present, bulb light. Test run approx 1 hour, no problem.
    On the car won't start with this EDU.
    Car start with other, donor EDU...
    What is the problem?
    Any suggestion?
    Tom
  17. #225
    Nov 2009
    Hungary
    Hi Tom_x
    Probably missing the 170 volt initial voltage.
    The 12 volt holding voltage is working.
