shortcircuit in this place. Any idea?
castin (15th December, 2017)
Thanx Pepita, what is the first current consuption after connect power?
Pepita please send me biger scheme for this unit (if possible).
ThanxI have heard that it is necessary to use a min. 10a
Without solenoid valve: 0.2 ampere
I now, but for start converter i need min 10A powersuply?
Yes, it's about 5-10 amps in operation.
Can not you test the battery? (10 A through fuse)
Im try test on table, but my powersource is to low. Im try on car. Thanx for help and info.
Could anyone tell how much ripple is on +130v line ,mine is stable but when loaded ripple is up to 50 volts ?
Hi to all
I have edu for repair but it have many voltage missing like some 12 and 160 voltage
any idea
Hi friends , i need info image of this components sB1
Schottky diode ?
I have 2 drivers that should work and do not work. 170V on the 10uF capacitor is, the current consumption in the stand is 180mA. How to run it without a car? I saw someone connect the 50W bulb and give the signal from the generator to one of the two inputs. Just what signal, 0-5V or 0-12V rectangular whether it must have a proportional filling?
My merida`s ecu got problems, desoldered and found a blown capacitor. What to check next ?
Check the voltages...
