Results 1 to 8 of 8
    Dec 2020
    Finland
    Default Audi A6 C5 and Injection pump swapping. ECU PIN code lost
    Hello!
    Audi A6 C5/2,5l V6 TDI/MY02
    The injection pump control unit is broken and had to be replaced from an intact used car. We tried to change the pump, but we could not find the required PIN in the instructions. Can anyone help?
    Instructions we received
    Determining VIN & IMMO-ID
     Engine Control Unit (ECU)
     [Select]
    [01 - Engine]
    Look at the first "Extra" field. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
    [Close Controller, Go Back - 06]
    ---OR---
    [Select]
    [01 - Engine]
    [Meas. Blocks - 08]
    Select Block 081.
    [Go!]
    The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
    [Done, Go Back]
     Injection Pump Swapping
     Prerequisites:
    • The NEW Injection Pump is installed in the car.
    • Battery voltage at least 12.5 V.
    • Make sure to have the Immobilizer PIN, for the Engine Control Unit (ECU).
    [Select] [01 - Engine] [Login - 11]
    • 4-digit PIN
      • The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234.
    [Do it!] [Adaptation - 10] Enter 050 in "Channel Number". [Read]
    • 4-digit PIN
    [Save] [Done, Go Back] [Close Controller, Go Back - 06]
    • Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
    • Start the Engine to verify the adaptation was successful
    Motor ECU files are read AVDI (Abrites)
    Aug 2015
    Latvia
    Hi, for PIN need to read eeprom 24c04.
    Dec 2020
    Finland
    What program would find out this?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by V3lmu View Post
    1 - open ecu
    2 - find out eeprom
    3 - desolder
    4 - read in programmer ( a lot of programmers can do that )
    5 - post dump here
    need help
    now my goal is to buy xp-005
    who will help?
    Dec 2020
    Finland
    Sorry, it not possible. I don’t have a soldering iron or an eeprom reader.
    Can't get the pin code from a file I read? :O
    Aug 2015
    Latvia
    Can't. Go to someone who understands what he is doing
    Dec 2020
    Finland
    Okay. I got advice from a car tuner. He was able to decode the eeprom, without decompressing the engine ecu, but unfortunately these codes were not working.
    These codes were obtained:
    eeprom 24C04:
    PinCode: 4060
    Try both pincodes, if the pincode is to short add zero at the begin
    eeprom 95040:
    PinCode: 3737
    Try both pincodes, if the pincode is to short add zero at the begin,
    I don’t know what program he used to make these visible.
    We will next try such a device. http://psgtools.eu/cms/?q=content/vw-audi-skoda-v6-25tdi-vp44-tool
    Hope this works.
    Aug 2015
    Latvia
    Hi, this tool is only for pump coding. Best tool for VAG cars is VCDS, all info about procedure pump swapping is in Ross-tech wiki site.
    Not all pumps is interchangable. What letters are at the end of old and new pump numbers ( A, B, C,.....?)
