Results 1 to 4 of 4
    Nov 2020
    newcastle
    Default Meriva 1.6 8v ecu help
    Hi I've got a meriva with an ecu fault. I've managed to get a second hand ecu but how do I retreve the car pass code from the second hand ecu as the last owner didn't have it Thanks
    rafal's Avatar
    UK - PL
    Use search.....you will find here all what you need
    Do not be lazy......
    need help
    now my goal is to buy xp-005
    who will help?
    Nov 2020
    newcastle
    I have but can only find diesel models
    Jun 2016
    UK
    Quote/Copied/edited from another post on here ... & assume mk1 Meriva Z16SE/Z16XE HSFI 2.5
    "-Get pincode from ecu with carprog or fvdi, or clock set (with opcom) if you have matching clocks for new ecu
    -Then reset ecu with same tools (or proper scanning tool)
    -then under immobiliser use program function and adapt used ecu to immobiliser.
    -only thing left is set vin and options of car(aircon, cruise control, automatic or manual, ect.)"
    Reset bcm/ipc to finish
  5. The Following User Says Thank You to 900ss For This Useful Post:
    titodash (23rd March, 2021)
