Dear Euroscan:
I have the following problem:
I need to change the ECU H?brida M1.5.5 for an Alfa Romeo 156 and i don't know the Pin Code because the immo doesn't have a serial memory. Only come a Microprocessor without a serial memory- The Micro has 44 pines and i do not know which is the pinout for reading it.
I need a dump for the ECU h?brida M1.5.5 for Alfa Romeo with Immo OFF in order to write the ECU with galletto.
If you have not the dump with IMMO OFF, I would like to know:
- ?Do you have some dump for 24C16 for this ECU?
Would you please post it?
- Do you know if the Pin Code is in the 24C16 too? ?In which part (hex address)?.
I need to know how tor read the Pin Code on the ImmoBox which doesn?t have serial memory.
Or I need a dump for the ECU with Immo OFF in order to write the ECU with galletto.
Thank on advance.
GJPadron
GJPadron.
I found a immo off file for the ME3.1 but I'm not sure how to use it. I've written it to the ECU but it's still coded.
Does anyone know how to immo off a ME3.1? Thanks in advance!
Any one have a virgin reset solution for this ECU ?
I'm happy to pay for your knowledge!
Darwins..
- make boot mode, SDA to gnd.
- upload immo-off file
- reconnect SDa pin.
- upload original file.
- i have yet to see this procedure
Hi euroscan,
Do you have a immo off file for this ecu?
Thank you!
This system is called ME7,3,1 too?
GOT question...
whats the spots marked SDA, AND SDL.....??
Thnaks
ps...nice pics!
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
Im looking for somebody who is able to immo off, virginize, Alfa 156 ME3.1.<br><br>Anybody?
ME7EEPROM programmer read. as 95080 . Clear to FF, instal to car. Ign on-15sec-ign off-15sec-Ign on-15 sec -off 15 sec. Start car. Tested OK in Alfa Romeo 156 ME3.1
Sudnut (16th December, 2023)
hello i have the same problem , i make all eeprom ff?
hi guys, i'm in the same situation. after cleaning the throttle body the idle oscillates between 1500 and 2000 rpm. the only solution is immo off of the ecu?
