Yes, I have ZedBull. Need do "transponder production" in zedbull menu ? After precode to car? Yes?
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
proceedure for using seondhand remote
1, replace 7946 with new chip
2, precode with zedbull or similar for renault use
3, code to car with ,,truecode/ad100 etc
Thank you for all. I understand.
If not, read 93c66 dump in the UCH and post it here, you will be given the APV of your clio, or read the ISK code from UCH and also you will be givven code ( if not too complicated for you read ISK, easier reading flash )
And with APV the new key will start the engine and the central locking will also work, both the same time, no need reprog two times, one for engine one for locking.
For the correct operation control key 7946 's got to be thrown into the precode before programming. Or is it just part of the chip will work, but the control does not work.
New keys bought specifically for Clio Campus are factory precoded ID 46 so they must be programmed only on the car with PIN car, engine and central locking will function at the same time after a good car programming ( ddt, clip ... )
Only new chips PCF7946 must be precoded Renault ID 46,
Renault keys bought from a dealer are already ID 46 preprogrammed.
