Results 1 to 15 of 23
    busaman's Avatar
    suffolk uk
    Default mazda demio immo fault
    mazda demio immo fault 1998 with no start battery since went dead it has the lucas 28as immo box s/n 6844021853 i need either a solution to repair or immo off please.
    Meat-Head's Avatar
    going to have to be slightly unhelpful.
    ring dealer and ask for the security code for immb, 12 didgit i think
    then look up 'mx5 transponder programming' or "ford probe II"
    and hope it's the same, reprogramme key as per instrctions.
    Not no hope of looking for data at work as flat out!
    hang on, do a search on here think somebody can help you out, but don't remember thread or who replyed! For the pin code
    Yes or no did you manage to get hold of thet 'other' off your mate? Thanks
    busaman's Avatar
    suffolk uk
    its already been to the stealers and they told them they cant code it so i will have to unlock the pcm or replace it just taken it out and found 93c56 eprom is that the one i need to read.
    ecu is denso 279700-0431
    Meat-Head's Avatar
    Unable to help with eeprom decoding, so i'll just drivvel on a bit, something might help you.
    1) All main stealer only employ two types of worker
    a) Normaly under 21 years old that can't read or write, wear brand
    name underwear, small car that's a bag of crap with a bird
    that's jamb hot, but serves pizzas
    b) Those that are two old to understand how a computer works
    or are unable to remember what to do.
    2) If the car has had flat battery, it is possable that the customer
    had tried to push start the vechile and slipped a cam belt
    worth checking as M-H-M had one that would start run die
    it (lost spark or injection), can't remember how, but we got it
    down to immo box, new box ordered, got 'dick-weed locksmiths ltd'
    to code it in, (igition on/off x times) and it still wound't start.
    somebody mentioned cam sensor, so put one on, still no go
    then managed to get of somebody at dealer that was ok
    he said something about 'cambelt', removed the cover, spring
    waving hello i've snapped.
    Altough was 16 valve the timing was out enough for the ecu to
    think, problem, shut down, but not enough to twat the valves.
    New cambelt kit, fired up instantly. We told the customer
    the cam sensor went dead short, which blow the ecu, which blow the
    immo box. Ecu was 'Repaired' new immo new camsens sir and off she goes.
    3) *THINK* the immo light only comes on if it has a fault, (unplug arieal, or screwdriver ignition see what happens)
    4) Look here see if helps you http://www.digital-kaos.co.uk/forums...mmo-1-a-85548/
    5) http://www.digital-kaos.co.uk/forums...in-code-80517/
    6) Mazda MX-5 Miata Resources
    7) sorry unable to offer anymore help on this one
    busaman's Avatar
    suffolk uk
    im pretty sure its in the 93c56 i will read it tom perhaps somone here can do it.
    Meat-Head's Avatar
    Quote Originally Posted by busaman View Post
    Give user http://www.digital-kaos.co.uk/forums...rs/67210-z786/ a kick in the vistor message to post on here, he likes jap stuff and likes playing with eeproms!
    Hrrum 93c56, got a fettish for the 93cxx series
    before you go too crasy just have a 2 min peek at cambelt, just incase, as it is a feature the springs slips, you can never tell if got pushed off or not!
    z786's Avatar
    10 Steps Ahead of You
    ouch, kick gently mate
    im afraid i do kinda hav a thing for jap cars mate but the mazda is not jap, its ford in disguise
    i agree wit MH on the cambelt howeva if youv checked, im not sure on that particular model but it shud be the same as PATS system
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    busaman's Avatar
    suffolk uk
    Quote Originally Posted by z786 View Post
    do you have any way of decoding ecu the mazda dealer cant adapt the keys with a new immo box (which is lucas)
    z786's Avatar
    iv neva had the pleasure of working on a mazda (apart 4rm diagnostics) so im sorry cant help you on that bit, usually if you cant get anywer, try locating a scrap car of the same make model & year, rip out the ecu,immo box,key reader, transponder chip, swap em ova and fcuk the car off, good ridance
    busaman's Avatar
    suffolk uk
    i have now managed to get one key working but the other two wont play game so it might have to do.
    Meat-Head's Avatar
    Well at least it is a start.
    Just cable tie the working one to the transponder arieal and hope somebody breaks in and nicks the car.
    If you could explain a little more on how you did it, ie the gorey details, thanks.
    busaman's Avatar
    suffolk uk
    well i followed the ad100 procedure, i got the code from the stealer like i said only one key would re adapt a real arse of a job unlike any key resync ive done before i did it at least 6 times. but at least one works.
  13. #13
    Meat-Head's Avatar
    So at the stealer it must have been the under 21 year old that was unable to read or write, if only he had pretended the ign on on off sequence was a Xbox game, we would have properbly have got somewhere. Goes to show not even the main dealer gets things correct!
    if you look at my second post on here Mazda MX-5 Miata Resources
    on the screen is this http://www.quadesl.com/pdf/immoblizer.pdf
    don't know if it's the same, better worse or none of above!
    Thanks for the update, always nice to know what out come was.
  14. #14
    busaman's Avatar
    suffolk uk
    must have been the spotty berk in the corner.
    but there is another problem with the ecu. if i could get immo off for 93c56 im sure that woul fix it.
  15. #15
    Meat-Head's Avatar
    must have been the spotty berk in the corner..
    Wounder if it was the one that sits in the corner on the bosses motorbike, eating sandwitches and farting loudly.
    thought afterwards, sometimes doing keys in same session add the other keys, think once you have two keys the third will 'diy' programme.
    What is the problem you r having now?
