Results 1 to 12 of 12
Thread: golf 4 immo off
    nairobi kenya
    Default golf 4 immo off
    hi all
    i need immo off for golf 4 .car will start and go off .no dtc in immo .dtc in engine is, ecu blocked by immo .if i recode ecu its sucessful but again car does not start
    key light come and goes
    ecu is 06a 906 019 bq
    siemens 5wp4459
    eeprom 93c56
    Prijepolje-Serbia
    Quote Originally Posted by automatemad View Post
    hi all
    i need im*o off for golf 4 .car will start and go off .no dtc in im*o .dtc in engine is, ecu blocked by im*o .if i recode ecu its sucessful but again car does not start
    siemens 5wp4459
    eeprom 93c56
    You can try other things first, like reset ecu and immo to factory so they can pair... try to read key, check errors in 17-Instruments....
    Mikeli
    nairobi kenya
    tried that but still no sucess
    no dtc in instrument
    tried reset to factory settings
    treo's Avatar
    R
    Helo you can try this file.
    South Africa
    Hi pls need your help
    I used your dump for siemens 5wp44 it starts and runs but
    when I switch off car and try to restart it starts and dies
    then i reflash the 93c56 again and the same happens .
    Is there a way i can stop the 93c56 from reprogramming itself.
    thanks regards
    Europe
    ecufix try this dump...
    South Africa
    Thanks guys all dumps work
    my problem was that my programmer gives me 93c56 in 8 bit and 16 bit versions and i selected 16 bit
    regards
    DK Veteran sosmecano's Avatar
    Oct 2010
    PROG
    Quote Originally Posted by Nocni View Post
    pass pleasse i need dump
    Apr 2011
    ty mans
    Oct 2010
    PROG
    pass pleasse i need it 2
    Jun 2011
    near bigest capacitor
    Quote Originally Posted by mikeli View Post
    Mikeli
    i have same problem 93c56 dump is corrupted what i have to do?
    Jan 2017
    please please can I have the pass
