I really I can not access the program.
dealer sent me the photos if I wanted to buy the software.
but this is really very high price
sry
sry
Hi. I can?t run the soft. I got Java version recommended here of course, but msg say: UNABLE TO LAUNCH THE APPLICATION . Any idea what happens?.
See pic.
Thanks to all
Try uninstalling that ver of java 6.10 run the servmaxx.exe while online it will find the correct java and install it, Maybe
you got a bad download. Just a suggestion that would be the first thing I would do.
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
I get the same error if I'm not hooked up to the Internet... and for some reason, you have to Run as Administrator with Vista or Windows 7 in order for it to work.
Also, I've been unable to get any reg key to work for Windows Vista & 7 .... XP, its not a problem. Have you had any luck with Vista or 7 running ServiceMaxx?
Hey code someone please post a code for me
PC ID - FFFF-FFFF
Thanks in advance
You ned to right click on the servicemaxx icon and run as admin to get the correct code to enter or it will not work. Hope this helps.
sorry wrong key if it comes up all FFFF-FFFF then you are running it on windows vista or higher. So you have to run it as admin.
Hi:
I had to rebuild my laptop yet again one more time...because of Virus Building Mongers on the web!!!
Im having a problem installing Service-Maxx....
I installed the correct Java version but...it still tells me to uninstall it and install correct java version for program to work?....any ideas? im using Java 6 Update 10....
Newest java version is 6 update 22. The java u have is too old.
My ServMaxx is working good with java 6 update 10, will updating java give me any benifits?
if its working leave it alone. update 20 messed up dlb and servicemaxx a while back for alot of people. I dont know for fact but doubt you will gain any servicemaxx features by updating java. what version servicemaxx are u using?
just a FYI, I updated to Java 6.22 and my servicemaxx would not work kept giving me the same errors a prior member posted, I uninstalled java and then let service maxx direct me to java 6.10 and its back up and running!!
