NAVISTAR SERVICEMAXX - Page 2
Page 2 of 110 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 1643
  1. #16
    DK Veteran ibmman's Avatar
    Living Hell
    Quote Originally Posted by jacques6925 View Post
    where can i get SERVICEMAXX FLEET PRO with crack or can some one point me in the right direction thanks Jacques
    Do a search it is on DK.
  2. #17
    Quote Originally Posted by superc0 View Post
    this download is full , i download it but is 1.65 mb, is it rigth?
    how i can register it?
    uncompress, run, install java, press the central buttom. enjoy
  3. #18
    WHAT VERSION OF JAVA DO I NEED TO INSTALL IT WONT TELL ME IT JUST KEEPS SAYING I NEED JAVA WHEN I ERASED THE VERSION I HAD I STILL WONT TELL ME WHAT VERSION I NEED PLEASE HELP THANK YOU IN ADVANCE
  4. #19
    DK Veteran zds's Avatar
    Russia
    Quote Originally Posted by dieselman77 View Post
    v.6 update 10
    Deposit Files
  5. #20
    leave computer hooked up to internet , It will get the proper java itself when you try to install software .
  6. #21
    Quote Originally Posted by dsskaren View Post
    what communication protocol are you using to communicate, I went to nexiq usb link and there must be 100 different choices.
    thanks,
    josh
  7. #22
    Quote Originally Posted by joshplainfield View Post
    thanks,
    josh
    If you are using NEXIQ usb just pick NEXIQ usb It will pick the proper protocol same with blue tooth .
  8. #23
    Ok so let me make sure i understand, I just select nexiqusb and don;t select anything else, it shows like 50 diff choices after i pick nexiq usb (example can125, can250,can500,can2 125, iso2254) etc.
  9. #24
    DK Veteran mondao's Avatar
    usb-nexiq j1939
  10. #25
    Member DonL's Avatar
    Canada
    Does anyone have a copy of SAINT or Service Assistant? I have one but it will only install on a Eztech??
  11. #26
    Quote Originally Posted by DonL View Post
    SAINT or Service Assistant? can be found here
  12. #27
    Quote Originally Posted by mondao View Post
    usb-nexiq j1939
    got working, I just went to Nexiq USB J1708, then I chose the J1708 option and it hooked right up.
    Thanks,
    Josh
  13. #28
    DonL did you get it working ?
  14. #29
    I have Panasonic Eztech , could you share SAINT,Service Assistant and launchpad . thanks in advance !!!
  15. #30
    Quote Originally Posted by hazim_avr View Post
    try this file
    only panasonic lap top work
