Hi guys ,, any body have NAVISTAR SERVICEMAXX please ... i need it thanks in advance
MEGAUPLOAD - The leading online storage and file delivery service
the proper version of java required to run servicemaxx was not detected.to ensure the correct version is installed,you must first exit here and uninstall all current versions of java once you have uninstalled java return and here and you will be prompted with a link to download the correct java version from sun microsystem
thank you very much m8 .. could you tell me how can I license it please
gracias camarada la verdad no entiendo nada de lo que escribiste pero deja descargo tu archivo ...
nuevamente gracias
sorry amigo gracias por correguir
http://www.megaupload.com/?d=6R9UZNKI
someone comment if this software works well, please
I have not yet tested in trucks![]()
It has lot of bugs to be worked out at dealer level . some disconnction problems ,does not list vt365 for 2007,2008 or 2009 .! I tryed to connect to a 2007 ce bus with vt365 & it keep disconnecting me ? ,Tech support said it has bugs to be worked out . (new software always like this ) Sould be great program when updates come.
where can i get SERVICEMAXX FLEET PRO with crack or can some one point me in the right direction thanks Jacques
Hi Guys
Please I need EZ TECH launch pad , thanks in advance
