Page 5 of 110 FirstFirst 123456789101555105 ... LastLast
Results 61 to 75 of 1643
  1. #61
    Default java
    domnloaded link tried to install says missing dll file deleted and tried to reload same message. thanks for the help
  2. #62
    Quote Originally Posted by MDR72 View Post
    What dll file is missing ? Did you download complete file than run it ? or just install from the web ?
  3. #63
    Spain
    Thank you MONDAO!!! My license is now until 2147!!!!!!!
  4. #64
    Newbie Rakof's Avatar
    Thanks for your help
    my servicemaxx works well.
  5. #65
    DK Veteran mondao's Avatar
    Quote Originally Posted by Rakof View Post
    when you have the chance of doing a performance test of cylinders, tells me how it works this software, please
  6. #66
    Hey Mondao
    When checking cylinders you can perform injector disable test , engine running ,temp obove 160 .some will do auto injector test , some you have to do it manualy 1 cylinder at time (it kills fuel to the cylinder you are checking . A good cylinder will drop in RPM alot. (like bad engine miss).
    when you have a bad cylinder say #2 all it means is that cylinder is not working proper.
    Do Relative Compression test if # 2 comes up low , you will have to do manual compression test ( could be bad valves,piston /rings etc .
    If # 2 come up good on manual compression test valve cover has to come off ,check rockers & valve springs if all ok probley getting into bad /pluged injector.
    note I use Nexiq connector on Maxx Force engins I use 1939 protocol on all others I use 1708 .
    Still lots of problems in Maxx Force software ,sometimes I cant get into ECM at all. Than I use Service Assistant with IC4 connector & never had one I can't get into . Yes I have updated my Nexiq drivers ?
  7. #67
    DK Veteran superc0's Avatar
    MEXICO
    Quote Originally Posted by rp1210a View Post
    mondao, what only 6 years before it expires cmon keep trying you need at least a 50 year license
    peter, just cleaned it up. I got to stop being such a cheapo and contibute to this great forum and get more pm space.
    "A88C" GOES TO EXPIRATION APRIL 2023
    IF THIS WORKS FOR OTHERS ONLY TRY.
    SOFT FOR ANDROS BENCH 6330 HELP PLZ.
  8. #68
    Quote Originally Posted by dsskaren View Post
    Hey Mondao
    thank you very much, now I understand
  9. #69
    I need your help
    I have a nexiq usbbt, but does not work when I start the program servicemaxx this is what happens
    1 - Progress Detection "initializing"
    2 - Detecting Engine Type.
    3 - Searching for Engine.
    4 - probe switching protocol.
    6 - Cable Not Connected.
    try to run for 15 seconds and disconnect.
    which protocol should I use? (Bluetooth).
  10. #70
    I need your help
    j939 on new trucks maxxforce 4300.4400.
    J1708 truck oldies 4700 0 4900
  11. #71
    MANY THANKS,
    I JUST ASK IF IT WORK WITH IC4
  12. #72
    servicemaxx try to connect, cant find engine
    1994 t444, DIT, nexiq usb link, is the truck to old???
    do i need different software???
    any help would be appreciated
  13. #73
    Quote Originally Posted by bnolann View Post
    SERVICE MAXX Work with all models , may be the problem with soft ware , try to select nexiq usb-link j1708 with old model and j1939 with maxx force new engine.
  14. #74
    Quote Originally Posted by hazim_avr View Post
    SERVICE MAXX Work with all models , may be the problem with soft ware , try to select nexiq usb-link j1710 with old model and j1939 with maxx force new engine.
    updated drivers I think that was it
  15. #75
    use MD32 to diagnose the 444 DIT engine its work very well .
