Results 1 to 8 of 8
    Feb 2015
    Lincolnshire
    Default OP COM keyless Astra H learning new CIM
    [COLOR=var(--primary-text)]Looking for some advice with coding on an Astra H keyless start.
    Suspected faulty CIM module, so iv got a second hand one with same part number. iv got the pin code to reset it and it accepts it. Plugged opcom in and reset cim, but cannot get the original vehicle pin wrote into it because i have no way of getting the ignition to turn on to get communication with the ecu.
    Learning reset CIM into the vehicle by resetting it, then choosing installed new cim in the immo option under cim module.
    I usually reset all modules then go into bcm and it learns it all in together, but its giving me an error and saying original pins wrong/timeout error, but im assuming that’s because theres no ignition on.
    Pin code is definitely right as the radio accepts it.
    Any help would be appreciated. Thanks
    [/COLOR]
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
    Member bendy's Avatar
    Mar 2009
    Essex, UK
    Hi Dayo,
    On Fords with keyless I know to program a kvm (keyless module) you have to bridge the Ignition Relay, perhaps the same on Vauxhall, also where did you get original pin from as a lot of later models radio code is the carpass but not always the case.
    Read 35080 in clock cluster to confirm correct pin.
    Feb 2015
    Lincolnshire
    Quote Originally Posted by bendy View Post
    Hi Dayo,
    kvm is keyless module in landrover/jaguar/volvo. we bridge pins in vw kessy plugs to get ignition on. i dont know away to get ignition on with keyless vauxhall or if its even possible?
    Mar 2009
    Essex, UK
    have you tried bridging ignition relay ?
    and yes KVM / RFA same thing /ford landi volvo jag,
    Feb 2015
    Lincolnshire
    i havent no, do you have a wiring diagram or fusebox layout for it?
    Feb 2015
    Lincolnshire
    im assuming terminal 15 relay is the ignition relay in the engine bay fusebox, R14?
    Mar 2009
    Essex, UK
    Hi could have two relay, one in fuse box under bonnet and one in rear fuse box, if car has rear one.
    Relays marked in red.
    Feb 2015
    Lincolnshire
    ill have ago tomorrow. Thanks
