Help with Renault midlum truck 2002
Results 1 to 15 of 15
    Alex
    Default Help with Renault midlum truck 2002
    hi everybody,
    been working for a week on this truck,
    it doesn't start, although both keys are intact,
    the self diagnosis screen of the car says "Defect 92" then shows a key picture with the words " theft defect"
    when i try to blink errors it shows the key picture with the word "TRSP" under it.
    now this seems to be a key problem, but i checked both keys and they seem ok,
    here is detailed info:
    key Meg 13 transponder (FF 81 34 4C F5 9D 46 3A)
    im*oblizer is texton L shaped, with 93lc46b eeprom renaul midlum immo 93lc46b 2002.rar
    ECU is BOSCH 0281010966 with 24c16 eeprom 24c16 renault midlum2.rar
    i'll post dumps, hope i can get it's "defect" cleared, or even it's im*obiliser turned off forever!
    my notices:
    defect remain even if i unplug the ecu,
    defect change when i unplug im*obiliser, it shows something like connection-cut drawing.
    thanks all.
    benci1982's Avatar
    Slovakia :((
    see how it goes Reversing lamps!!!!!!!!! then look fuses
    (Immo + Reversing lamps) 1 fuse
    sorry me bad englis
    benci1982's Avatar
    Slovakia :((
    or unplug radio, + take out these (see image)
    Alex
    thanks for the reply,
    but what do you mean by reversing lamps? i hope you can explain a little more,
    and what should this do? remove the error message ?
    DK Veteran Xram's Avatar
    Glasgow
    Quote Originally Posted by frdnwr View Post
    He means the reverse lights run off the same fuse as the im*o check the reverse lights.
    Alex
    in the picture i see the 93lc46 eeprom removed, shall i remove it too? or just the marked pieces?
    i'll check it tomorrow and post results here..
    Alex
    hi all,
    ufortunately, noting of the above worked for me, unpluged radio, removed those four pieces from immo box , stil car shows exactly same errors using any key .
    reverse lights checked, working fine.
    i hope there is a better idea?
    Sep 2011
    in africa
    Default renault midlum immo activated
    hi mate
    i have same problem like FDNWR with same truck same ecu and immo number thank you very much brother i appreciate your kindly help to us suzuki started
    but i still need help from you
    i have renault midlum 220dci no starting shows key on dash and display massage on dash immo activated checked key with tango key seems good read immo check looks good i would like to get help if possible to immo off it i checked also all fuses are ok detaails are :
    on renault truck ecu bosch 0 281 010 966
    renault 5010550351
    24v
    eeprom 24c16w4 edc15 plz i am far 300km from my workshop
    i need help from you guys i am in 300km far from my workshop i need serious help
    2 keys data readen by tango are : 20 C6 CA F9 11 and 20 C6 CA 5E 12
    regards
    Alex
    Wish I could help you my friend, all I know is that this Key can be made using TMPro .. GoodLuck
    Egypt
    Sep 2011
    in africa
    thanks brother
    just make other new key and start and leave the 2 old keys ? so just keys corrupted ? or immo dump ?
    regards
    Alex
    listen at that time , I tried disabling the immo but it didn't work, that guide about removing the resistors didn't work for me.
    that was long time ago, in my opinion , both immo dump and keys were ok, there was something blocking the immo from functioning properly, but that was in my case, I don't know about yours.
    Egypt
    Sep 2011
    in africa
    hi
    my friend i need exacly solution you did on your car if have been started if you made keys ,or other solution in wiring change ecu ,made new transponder or any solution if you made new key the key you made was same data or you selected other key number that is all i need to know because myself have got immo off from a friend but dint work he asked me if my ecu is MS6.2 or MS6.3 those are solution for immo off but dont work on those ecus like yours and mine because there is no MS6.2 OR 6.3 sO if my dumps are corrupted i can copy yours if was good then find key from some friends
    but i need exacly solution you did if car has started plz i am at 300 km far from home i mean workshop
    i tried even to remove eeprom from ecu and start but with no solution so i need what you find out from your car
    regards
  13. #13
    Sep 2011
    in africa
    no one can help on this ?
  14. #14
    Alex
    Sorry , the car didn't start for me at that time, I couldn't solve the problem...
    Egypt
  15. #15
    Jul 2016
    hello,
    i have problemthat car don't start, please help me
