The difference is mainly in the parameter setup, linehaul will have cruise control set up for the particular OEM etc.
There may also be calibration differences such as cruise control gain and fueling tables set up for linehaul operation.
Vocational will have PTO set up to suit the OEM and calibration differences such as low speed fueling tables more suited to the type of operation expected by the type of vehicle.
Ok so I just got the August 2010 Incal set up and when I hooked up to an ISX CM870, Insite could not find calibrations for the selected ECM Part number which is 3684009. Anyone know why the cal isn't there? I opened up other Cals for different ECM numbers and they show up. Anyone know what's wrong?
Sorry Guys. I turned idiot for a moment. I didn't select the proper certification code.
Hi there
To make a harness up like in the pictures Mondao posted does anyone know what pin goes to what or where and exactly what is needed or even where i can even buy the correct cable
Cheers
Len
I get the yellow symbol comport and I can not connect I get error, I can do I can help, thanks
A friend of mine gave me a cable the 3-pin, 2-pin data cable for the cummins inline interface. He doesn't do programming so he didn't need it. It's cummins part number 3165141. I use the nexiq usb-link so i cut the 25-pin connector off and wired it to the Deutche 9-pin plug. However I can't seem to establish a connection when hooked to the ecm of an ISX. It's just like the cable in post 50. Anyone got any idea? I checked the power/ground and checked the J1939 wiring. It should be working
Hello Texas149,
check this thread out it may give you your answer. The fallows there did great work getting all this put together. The pictures are also their work. I just got it all together for you to make things easier.
Link:
http://www.digital-kaos.co.uk/forums...06/index8.html
I feel your missing the 120ohm resistor needed for the J1939 on your adapter to work. The Communication Area Network or "CAN" signals travel on this backbone, there are two end of line resistors to total 240ohms. so when your connection is presented, your J1939 connection needs to have an in-line 120ohm resistor on the CAN Low side or your connection will never communicate. the pic diagrams show you were things go. the pdf has the connector lables help ID pin locations. again this is all their hard work. thank them if it helps you. ( zds, hercamp, mondao, alsop, jctech, peter21)
Hope this helps you.
jctech,
Thanks for your input. That is correct. combined input will resort to Texas149 to solving his problem. I have attached some pdf doc's that will help Texas149 a little more.
Texas149,
these pdf's have pinouts that you can use to test your connections. if any thing we'll get you wired stright.
Cheers fallows Share On...! Woot Woot
Hope this helps.
Hi there
Can anyone help, i am looking for a calibration file for a
QSB 5.9-205
ECM
Type: CM550
P/N 3990517
E/C J91691.01
Do you know where i can find ? got incal august 2010 DVD 1 and 2 but dont seem to be anything to match on there ?
Len
