    Jul 2014
    England
    Default CORSA D PIN FROM ECU FLASH ??? PLZ
    HI ALL IS IT POSSIBLE TO GET THE PIN FROM A CORSA D ECU FLASH READ? NEEDED TO RESET SECOND HAND PARTS SOMEONE FITTED. THANKS IN ADVANCE
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    I think in eeprom .But You missed a lot of data ex. type of ecu nr etc...
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following User Says Thank You to drewdom For This Useful Post:
    Leesjake (31st March, 2021)
    Jul 2014
    England
    corsa d vxr 1598cc
    bosch me7.6.3
    full flash read of ecu
    using albrities
    this is not the original ecu to the car someone has put parts on and got it to start, many other faults
    drewdom's Avatar
    Aug 2010
    Abrites or fvdi? Enyway you should do read with this tool to pin with this tool.
    Aug 2015
    pin is in eeprom , i found that carprog don't work on these ecus despite connection diagram on their site but if i remember correctly fvdi opel works for reading pin at least
  7. The Following User Says Thank You to dtip For This Useful Post:
    drewdom (1st April, 2021)
  8. #6
    Aug 2015
    Quote Originally Posted by Leesjake View Post
    corsa d vxr 1598cc
    bosch me7.6.3
    using albrities
    if you have abrites then put ecu in car and go to read pin on obd!
  9. The Following User Says Thank You to dtip For This Useful Post:
