Results 1 to 15 of 18
    Nov 2008
    Default dm800 flash problem
    ok so i got a dm800 from dreamboxcom.com. they said it was an original so i flashed pli-enigma2-jade3-dm800-20091005-6705.nfi via the web interface.
    rebooted the box and got the "erro1 no ca found"
    ive now tried every way to reflash the box.
    when using dreamup i et the inital error of "invalid integer..."
    then i use enforcer to try flash the bootloader but get the "file to big" error.
    when i use hyperterm to com1 i get this msg
    (c) 2007,2008 Dream Multimedia GmbH. All rights reserved.
    Dreambox DM800
    FIRST STAGE 1.00 {BO23456}
    2ND STAGE OK, build #75 (20091005)
    0.000 - BCM board setup
    {00000126,00000126,00000125,00000124,00000123,0000 0133}
    0.007 - fp init
    0.008 - ca init
    CA invalid
    OLED found!
    NO CONFIGURATION DATA PRESENT. STOP.
    * ERR01: NO CA FOUND
    do i have a clone dreambox and is their anything else i can do?
    pick what image you want from here Digital Kaos - Downloads - 2.1 clone images for bootloader 75
    i think you have a clone m8 not a orignall CA MEANS BOOT LOADER WRONG ok you can usel orignal image only in the muilt boot not in the flash on a clone try a image from the link you want used dream up and null moden cable
    V.I.P. Member dctyper's Avatar
    Jun 2008
    deffo not original for the price.
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    If you plan to run multiboot so put a img with the latest drivers on the flash. The box are using flash memory drivers also in multiboot. Becomes problems quickly if you have old drivers in flash
    Nov 2008
    Quote Originally Posted by kaitum View Post
    problem is i cant flash anything onto the box
    V.I.P. Member westkill's Avatar
    May 2008
    i had a similar problem with a clone a while back i think
    i had to use dreamup version 1-3-3-2
    and flash nabilosat v0.10 with bootloader 72
    which is in the downloads
    or bootloader72
    not 100% thou
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    i have the same problem
    DK Veteran deffc0n's Avatar
    UK/POLAND
    For all this problem please read my post this link:
    http://www.digital-kaos.co.uk/forums...-found-148229/
    hi. i have a clone and not working. is black view.the flash in the right is on but don't work. please help
    UK/POLAND
    You have connect box with Dreamup ?
    If the dreamup is not working you may need a patched Dreamup like DreamUP_patched_by_forhike_and_natas hiope it will help you
    i have the same problem.i try to put another image and now it show only "DREAM MULTIMEDIA",and don't start.
  13. #13
    ok.solve the problem.put sec. stage 7.20,then 4.50 for dm800 clone and work now.
  14. #14
    Member MyB5's Avatar
    Jan 2009
    Up north
    Quote Originally Posted by yoyo View Post
    Dreambox DM800
    0.007 - fp init
    0.008 - ca init
    CA invalid
    OLED found!
    How do I do this?
    I can't connect with any DreamUP. Not even through "2nd_stage_pack". I only get "calculating checksum" or "waiting for acknowledge". Is my motherboard bricked?
    Plz help!
    Vu+ Duo-BH 2.0.9,1
    CloudIbox II+
    DM600PVR & DM500
    Skybox F5 & F5s
    Oscam 9533 & CCcam 2.2.1
    0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
    Scandinavian
  15. #15
    Dec 2010
    err to big file in dreamup
