Page 2 of 44 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 649
Thread: diagun help
  1. #16
    DK Veteran sergej's Avatar
    Latvia,Riga
    JTAG-4pin
    TMS-pin J14 in c3s2440a
    TCK j13
    TDI H14
    TDO J16
    If unsolder s3c2440a you can see it pin.
    But this pin i think in 20pin usb connektor and diagnostic
    pin on board.
  2. #17
    Latvia,Riga
    Default Diagnostik pin
    Diagnostic pin DIAGUN
    T11-GDN
    T2- +3.3v power
    T40,T39 USB
    T3-nTRST-JTAG
    T4-TDI-JTAG
    T5-TMS-JTAG
    T6-TCK-JTAG
    T7-TDO-JTAG
    T9-Rx rs232(sp3232) +/- 15v in datasheet -can connect with PC COM port.
    T10-Tx rs232(sp3232)
    T38,T37 ?USB2?
    IN com.jpg com rs232 ttl(0-3v) for chip PL2303-USB-COM adapter from mobile tel
  3. The Following User Says Thank You to sergej For This Useful Post:
    twiganbone (27th October, 2021)
  4. #18
    kevfield's Avatar
    uk
    So is with this type jtag?
    and can you tell me what is diagnostic pin used for??? boot mode?
    Thanks kev
  5. #19
    Latvia,Riga
    Default connect with com port
    FOR INFO ONLY! I select format and died bootloader.
    For connect com port and If USB died:
    1.connect on USB-COM adapter from old mobile tel on chip PL2303(or another) pin1
    to pin12 chip sp3232 in Diaun ,pin5 pl2303 on pin11 sp3232,GND-GND,install driver PL2303.
    2.connect USB-COM adapter in PC.
    3.Click Start Control Panel System. Inside System Properties, click on
    Device Manager. Double-click on Ports (COM & LPT1). You should see the
    Prolific USB-to-Serial Comm Port -Double-click-install N com port set 1-4
    4.open HyperTerminal (Start > Programs > Accessories > Communications and select Hyperterminal and double-click Hypertrm.exe.)
    5.Type a name for the connection into the Name,OK
    6.
    Select the N COM Port-Prolific USB-to-Serial Comm Port
    7.Select 115200 for the Bits per second. Leave Data 8 bits, Parity No, Stop bits 1 and Flow control No
    8.ON Diagun.IN windows HyperTerminal you see menu BOOTLOADER!!!For update click space in pc or reset in Diagun.
    9.For restore USB- connect USB cable Diagun and click U in HyperTerminal on menu bootloader.
    10.In PC-new USB device.Driver in folder DNW5,USB driver.
    11.Close HyperTerminal and open dnw5.exe,in configuration-option set com port.
    12.Also you must using SiRFSoCMgr_v6.1.5. with com port.
  6. #20
    Latvia,Riga
    Attachment 44455
    Quote Originally Posted by kevfield View Post
    Thanks kev
    Yes.JTAG must only if died bootloader.
    Boot mode you can with com or usb .Open SiRFSoCMgr_v6.1.5.
    When USB-need driver USB in folder SiRFSoCMgr .
    Or HyperTerminal with com port.
  7. #21
    Latvia,Riga
    Default PIN JTAG Diagun
    T7-TDO
    T6-TCK
    T5-TMS
    T4-TDI
    1. Driver GIVEIO
    2. H-JTAG H-JTAG
    3. NoICE Download NoICE
    4.example install Digital Kaos
  8. #22
    miha99's Avatar
    EU
    check this out sergej, it is from working diagun.
  9. #23
    miha99's Avatar
    EU
    Also complete image from flash.
  10. #24
    sergej
    Where are locations on smart box for RST, VCC, VDD, i have original i will try and help but i need instruction.
    I see on your Jtag you have RST but i not see pin location.
  11. #25
  12. #26
    Latvia,Riga
    Quote Originally Posted by bellautos View Post
    sergej
    I use resistor adapter with LPT port !!! L cable<20sm!!!
    In board Diagun
    T11-VDD(GND-in board)
    T2-VSS-3.3V
    RST-in button reset(i no use)
    http://www.digital-kaos.co.uk/forums...ag-adapter.jpg
    In LPC2368 1pin-T14-TDO
    2 T12-TDI
    3 T11-TMS
    4 T15-TRST-reset
    5 T13-TCK-
    VCC-3.3v-see u11 or pin28,54,71,96.I no use.
    LPC2368-
    ARM7 with 512kb flash.I
    tried connect with JTAG,COM,USB in offline but no result
  13. #27
    did you power the pda with bench power supply or battery ?
  14. #28
    what are the target connections you choose in the software
  15. #29
    Latvia,Riga
    example
    recoverMIO.rar
    JTAG work only in winXP with driver GIVEO!
    Battery+USB(or power supply)
    In BIOS
    EPP mode(ECP+EPP),378
    In windows-set Driver GIVEIO!
    For ARM 9
    Setup H-JTAG,run H-Flasher-Flash Selection-HAND FLASH-S3C2440+K9F1G08-save as
    H-JTAG-detect target.If OK-see
    For ARM7-see ocd commander
    2 T12-TDI
    3 T11-TMS
    4 T15-TRST-reset
    5 T13-TCK-
    LPC2368-
    http://www.macraigor.com/ocd_cmd.htm
  16. #30
    Latvia,Riga
    Then setup NoICEARM,run -in options setup-target communication.
    Close and open NoICEARM-see
