Needed USB-com port
http://www.digital-kaos.co.uk/forums...=1#post1228360
usb to ttl have another level logic 0 and 1
Needed USB-com port
paro44 (11th July, 2016)
hello i have a problem with diagun .. its start and freeze black screen..
i have change samsung memory inside samsung . K9F1G08U0C but after i change it wont start anymore so i have put again the old samsung
https://www.youtube.com/watch?v=uZfzEHGTRm0
how can i fix the problem
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
K9F1G08U0C must be flashed before to replace the defective one in your Diagun
Good luck
how can i flash it ??? do you think that the problem is from K9F1G08U0C ??
i have g-tag so i need the wire connection and the flash
If the Diagun is not boot then you ahve to change that SAMSUNG memory
But this must be flashed before solder it in Diagun
I'm not very sure but as I remember the the dump for this memory was shared here
Maybe someone else who is active in the forum can help you to give you a link
If you thought that you can only buy the memory and solder it as it is then its wrong
That momery contain the rom ( windows mobile 5.0 ) and because its defectiv or not flashed then the Diagun do not boot up
Good luck
paro44 (21st July, 2016)
yes i have change it without doing any flash .. diagun does not boot up anymore...
so i will apreciate any help if some one can tell me the step tp dp the flash with j-tag or other tool
o have try to search on forum but i did not find it
have anyone run a demo IO test in emulator?
i run and get some errors.
anyone know what's problem ?
thank you.
9805_IO.txt
Hello ,
Maybe someone can share diagun3 tsop48 flash contents ?
Thank's
on my diagun emulator old version software working but on new version stuck at resetting
hello.
i am new to this forum.
can you please help me with Launch X431?
i want to use it with the Windows CE Emulator i have on my PC.
i followed everything you said but i am still stuck.
do you have a video or a tutorial that can help me with all the attachments and items i need?
thanks for your time!
Congratulations to the New Year !
New emulator
https://yadi.sk/d/dbbbh1te36ELzw
Unpack on C:
Create on C: folder Storage Card
Copy your GAG to folder Storage Card
Start Diagun.bat
Edit Diagun.bat for your com -port or way Storage Card
hi sergej , i need latest display for diagun 2, and latest tata mahindra and maruti update , if you can post
