Did finally Fix this smartbox: http://www.digital-kaos.co.uk/forums...ck-fix-395188/
Only reason to start new thread was to find " Fix " easyer in "searhing forum"
It belongs in here.
Last edited by Mrubbert; 11th February, 2014 at 12:09 PM. Reason: Serach forum for FIX
Hi.
What is problem if sometime or every time is disconnect in engine renault scenic 1.
Help connection whit ABS end back to connection engine then works fastens a few moments.
I think if problem is relay only who? this same problem is fiat
An expensive solution is buy a new " open serial smartbox " if you dont have it.
Put them on a work bench and start compare.
please help, I have smartbox connected to pc with toshiba bluetooh stack.
the first time I connect to the car and the serial appeared but I could not copy it.
then appeared: 1) Found new version of smartbox program
2) upgrading, it will take about 5 minutes , Ensure power remain. On
3) fault
then I tried to connect and appears only point 2 and 3 and not serial.
which is my problem?, thanks
Began process update your smartbox.
Wait 5 min!See progress bar.
But update possible only with any PDA Diagun,BT HC-05-d,BT HC-05 USB,cable.
Shop hc-05-usb online - Buy hc-05-usb for unbeatable low prices on AliExpress.com
Cable connect emulator
http://www.digital-kaos.co.uk/forums...ml#post1228360
began but no progress bar.
I try by serial cable but does not work
buy it HC-05 USB
the serial may be the problem?
as configured HC-05 USB?
You have HC-05 USB?
paro44 (17th March, 2014)
what problem serial cable?
Measure the voltage on Rx and Tx.
must be "-6 V"
If on Rx or Tx 0 V-Exchanging Rx and Tx.
I would connect the cable to smartbox as in photo with resistance.
the LED blinking red, but did not connect with the emulator and bluesoil
I also connected with the emulator, but if for toshiba stack
In your PC real com port?
Measure the voltage on Rx and Tx?
yes real port.
my pc panasonic cf-19
but also virtual port usb and not working
must be "-6 V"
Pin 2-RxD-a pin Rx en Smartbox 1,7 mv
Pin 3-Txd-a pin Tx en Smartbox -5,5 v
resistance 50,70 ohm
not working real r232
