Page 3 of 44 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 649
Thread: diagun help
  1. #31
    DK Veteran sergej's Avatar
    Apr 2010
    Latvia,Riga
    Default Soft JTAG Diagun
    MSP_2442sam flashing K9F1G08
    !!! pin in LPT no standart!!!
    Pin 2 LPT-TCK-pin T6 Diagun
    3 TDI T4
    4 TMS T5
    11 TDO T7
    In H-JTAG setting LPT
  2. #32
    Apr 2010
    Latvia,Riga
    Default Log
    Log loader Diagun.
  3. #33
    miha99's Avatar
    Sep 2009
    EU
    Tell me, you download image through USB or jtag?
  4. #34
    Apr 2010
    Latvia,Riga
    I can download image from JTAG,com,usb,TF card-but i no have file image.
    Diagun have multi soft(XIPKERNEL)-standart wince nbo file not work.
    1.If windows Diagun no light(died bootloader):
    I cropping Pages.bin from 0 to 247db0 (di4.bin) and flashing
    with JTAG- SMP_2442sam(SMP_2442sam.exe /f:di4.bin enter,1-enter,0-enter,0-enter).After reset windows Diagun light.
    2.When windows Diagun light connect com port-see menu bootloader-
    "Press [ENTER] to download image stored on boot media, or [SPACE] to enter boot monitor."
    Space
    "Initiating image download in 5 seconds.
    1) Boot delay: 5 seconds
    2) Reset to factory default configuration
    4) Program image into Flash: Disabled
    6) Format Boot Media for BinFS (except TOC, bootloaders, etc) !!!no use if lifes bootloader!!!
    E) Erase Reserved Block (Erase nboot, eboot, but Reserve TOC)
    S) Download image by serial---(SERIAL)
    F) Low-level format the Smart Media card (Include 'E',mark 3 bad block,erase block)
    L) LAUNCH existing Boot Media image
    U) DOWNLOAD image now---(USB)
    W) Write Configuration Right Now"
    4-enter( Program image into Flash: Enabled),then U-USB cable connect -PC found new device-driver in dnw5,start dnw5.You can write com -S,usb-U,TF card-L.But bin,nbo,img file-error type file.I think need TF card with NB02.nb0,chain.lst,
    chain.bin-Sorcery.exe no can made this file in Diagun Pages.bin.Its work manual!http://4pda.ru/forum/index.php?showt...0#entry4866798
    !I probe flashing Pages.bin with JTAG-SMP_2442sam-I think 80 o'clock!(+charging)
  5. The Following User Says Thank You to sergej For This Useful Post:
    taxo1965 (22nd July, 2017)
  6. #35
    miha99's Avatar
    Sep 2009
    EU
    Use diskRW and read complet nand flash image (from working Diagun) - save to sd card, than use H-jtag configure H-jtag server to nand k9F1G
    than burn complete image to nand flash (it takes caa 5-6 hours to program 127M image to nand flash).
    If you need complet 127MB image from Diagun nand flash just tell me.
  7. #36
    Apr 2010
    Latvia,Riga
    JTAG-slow channel LPT port,i want USB or TF card.I no have
    work Diagun.In post 23 image from diskRW?In adress 0-1FFFF=FF?Protection read or BinFS format 0,1,2 blok?
    In Pages.bin adress 00=37.I think If copy flash need 127m,
    if boot file (FW) for TF-30m.Need chain.bin-table adress
    file.
    In my log "BLOCK the bad block : 0x1
    Please restart board and burn NK again!TOC_Read ERROR: SectorInfo verify failed: FFFFFFFF FF FF FFFF
    TOC_Init: dwEntry:1, dwImageType: 0x2, dwImageStart: 0x0, dwImageLength: 0x0, dwLaunchAddr: 0x0"
    Also"MAC Address: 00:00:32:12:33:12"-if load other fw can problem with bluetooth?
  8. #37
    miha99's Avatar
    Sep 2009
    EU
    I use for my ARM device this bootloader for downloading over USB.
  9. #38
    Apr 2010
    Latvia,Riga
    Quote Originally Posted by miha99 View Post
    Tell me how install this boot.I think this for ARM9 board with
    NOR flash.
  10. #39
    miha99's Avatar
    Sep 2009
    EU
    Uf my mistake Diagun does`have NOR, look I have wigller and when I receive Diagun I will read content from NAND and send to you, please give me info for JTAG connections or pictures from yours connections to diagun.I think this solution will wake up your device 100%.
  11. #40
    Apr 2010
    Latvia,Riga
    Pin JTAG
    T7-TDO
    T6-TCK
    T5-TMS
    T4-TDI
    Pin diagnostic
    T11-GDN
    T2- +3.3v power
    T40,T39 USB
    T4-TDI-JTAG
    T5-TMS-JTAG
    T6-TCK-JTAG
    T7-TDO-JTAG
    T9-Rx rs232(sp3232) +/- 15v in datasheet -can connect with PC COM port.I no tried.
    T10-Tx rs232(sp3232)
    T38,T37 ?USB2?
  12. #41
    miha99's Avatar
    Sep 2009
    EU
    I still waiting for diagun but I attach wince 5.0 from arm which contain same samsung 2440 and k9f1G08 nand flash, you can test this file on yours device, but use h-jtag to burn and take time.
  13. #42
    Apr 2010
    Latvia,Riga
    Thanks you Miha!I tried.I unpack Pages.bin and have all
    file and modules Diagun.If you need i give in site.
  14. The Following User Says Thank You to sergej For This Useful Post:
    sandixxx (29th July, 2020)
  15. #43
    miha99's Avatar
    Sep 2009
    EU
    Yes please give me the site.
  16. #44
    Apr 2010
    Latvia,Riga
    Default XIPPort
    1.In new folder-nb00-unpack XIPPort,open XIPPort,press
    dump nbo-open nb00.nb0-when in window-OK-you have
    folder OUT with file,modules and adress.
    2.Then also nb01.
    My out file.
  17. #45
    Apr 2010
    Latvia,Riga
    Default QuickBINView
    Also you must unpack you nb0 file in bin with XIPPort-Misk -nb0>>bin.
    Then open bin file with QuickBINView.
    My NK.bin
