Results 1 to 11 of 11
    Top Poster Cordobe1's Avatar
    Dec 2009
    Argentina
    Default VW Golf 4 Inmo CODE
    Hi Everyone,
    Someone please tell me what code has the Golf GTI VIN: 9bwhe21j664006514?
    What is the procedure to add a new key?
    Tnks A LOT!
    El Cordobe!
    RASCH MotorSport
    Dec 2009
    Land of Rocks
    Quote Originally Posted by Cordobe1 View Post
    Hi Everyone,
    Tnks A LOT!
    To get immo code read eeprom from dash and post it here.
    Sep 2009
    Dec 2009
    Argentina
    Quote Originally Posted by tachonow View Post
    To get im*o code read eeprom from dash and post it here.
    Ok, With VAG-COM 409 could read it? Galletto 1260? KWP2000?
    Tnks a lot for the info!
    El Cordobe!
    RASCH MotorSport
    Dec 2009
    Argentina
    Quote Originally Posted by Alex789 View Post
    Tnks but the link is broken.-
    "There is currently no text in this page"
    El Cordobe!
    RASCH MotorSport
    Newbie spookauto's Avatar
    its very simple..use a vag com adapter en use the toool
    for dashes 4 vw....it wil give u the proper code ..
    toool is at software collection on rapid share,,,,
    Dec 2009
    Argentina
    Quote Originally Posted by spookauto View Post
    Tnks for responding!
    The tool for dashes is VAG TACHO? What version?
    TNKS A LOT!
    El Cordobe!
    RASCH MotorSport
    Sep 2009
    TNKS A LOT!
    You should have there dash 1J0 920 826A KOMBI+WEGFAHRSP VDO VXX. So, you can use TachoUSB 2.2 or 2.5 or something else. But if you are able to read with Galleto or KWP2000 eeprom from ECU, simply make it and upload here. In you car 1.8T 132Kw installed Bosch ME7 ECU. It's not a problem to find login there.
    Dec 2009
    Argentina
    Ok I will try to enter the vehicle with the cable VAGCOM, and VAG Tacho soft .-
    If I can get the file from the ECU Golf I share without problems.-
    Thank you!
    El Cordobe!
    RASCH MotorSport
    Apr 2010
    thanks! man this is a nice one
  11. #11
    Apr 2010
    Hello everybody.. I'm new to this
