You must take the airbag ecu, open it, and you will find inside eeprom or mcu to be programmed, woth a clear file ( softwares will clear your crash on your original file), then write it , and clear remaining faults using PP2000.
Just start, and all come itself!!!!!!!
Thanks for answer, is it possible via ODBII connector in PSA cars ? I already did it in 206,307 via desolder and reprogram eeprom but looking for easy way via ODB ?
NO, not possible via OBD socket, this will be in case of VAG, but not PSA, except if Abritus tools offers this feature, but Abritus stuff= Lot of money !!!!
You can make flash even if ou don't have access to Peugeot server, but not in all cases, depends on ecu version and PP2000 version, just skip the internet inquiry by pressing F4 and you're done..
try unintall this version, and install previous one like 22.xx..
Hi Alex,
I have a peugeot 607, recently the rear brake calliper was siezed so I replaced it from the scrappies..
since I have replaced it, it doesnt apply full pressure.. and I can see some rust grooves on the disc as if it hadnt been used.. I have done the bleeding to ensure there is no air in the system but still no luck..
can you advise of any obvious..
also what tool is used to the unscrew the bottom calliper screw? as there is less space on the bottom one..
hi,
I need halp with citoen bsi configuration 5 digit code, plaese can sombadi help me?
