Results 1 to 7 of 7
    Top Poster felix11's Avatar
    Liverpool
    Default Help with Samsung spoofed as Lite-on needed
    I have a samsung drive which has been spoofed with the info from a lite-on dummy.bin. Flashed with samsung ix 1.61 to as per Jungle Flasher guide.
    When u put a disc in it says "To play this disc put it in an a
    xbox360" (for real discs), for back ups it simply displays the white x360 screen.
    The donor drive (the samsung) had been previously spoofed as a lite-on (it showed as PLDs-16 in MTK 32 tab) so I unliocked it as if it were a lite-on, used dummy.bin as source firmware the spoofed source to target and wrote to it as a samsung.
    Any help/ideas would be appreciated.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    So you have a samsung drive physically? Then treat as a samsung. Dump as per being a samsung.
    What drive are you gpong to be wrote to?
    Samsung drive, unlock as a samsung.
    If staying on a samsung, load ix version of samsung into target, spoof. Should come at bottom spoofed as a liteon. Save file.
    Back to mtk tab and write it.
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    What is this sammy, liteon unlocketc. I never use this.
    Create a spoof of liteon dummy flash with samsung 1.61 and its all done.
    No need to unlock.
    Best way to do drive is in DOS. Create Sam_CFW.bin from liteon dummy and flash.
    Patience is a virtue.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    I dont m8 not any more, my motherboard comatable with all drives.
    I Unlock drive/dump drive/write drive. Outro, all done.
    When you get a spoofed drive you always treat it as what it is physically.
    ie you have a liteon 74 as a benq. Treat as liteon.
    Liverpool
    Thanks guys - solved problem now. Created SAM_CFW then flashed - worked fine. Sorry to trouble you!
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by felix11 View Post
    Yeah it should work like that as you got a samsung drive
    Jul 2008
    cmd
    No trouble mate. All learning
