Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 39
  1. #16
    DK Veteran vevepatronu's Avatar
    Jun 2009
    Romania
    ok m8 thanks, i can see some things here, but if you can do tomorrow more pics will be great. thanks once again
  2. #17
    Apr 2010
    Birmingham, England
    Quote Originally Posted by vevepatronu View Post
    No worries, I'll even draw you a little doodle
  3. #18
    adam28's Avatar
    May 2009
    UK Essex
    Checke here, dont know if it will help.
    http://www.digital-kaos.co.uk/forums...tor-schems.rar
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
  4. The Following 3 Users Say Thank You to adam28 For This Useful Post:
    ADUIR (2nd September, 2013), capi (30th May, 2013), stivencho (5th December, 2014)
  5. #19
    Jun 2009
    Romania
    i've seen that already m8.... but are not so good...
  6. #20
    adam28's Avatar
    May 2009
    UK Essex
    I have never tested it myself,to see if it works.
    Cheers mate
  7. #21
    Junior Member sideeffect's Avatar
    Jan 2010
    South Wales Valleys
    Are you looking for something like this?
    Got the files from this forum. contains everything pics, part list, dump setup etc
  8. #22
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    Default Renault decoder
    Is there anyone that got this tool built and working 100%
  9. #23
    treo's Avatar
    Nov 2009
    R
    Quote Originally Posted by rockero View Post
    Hello and greetings, I need connection scheme for SIEMENS FENIX 5 renault im*o emulator, since I bought it in the manual CODECARD and do not understand very well in the section on ECU connection ......... . could help in the connection to the ecu?
    Sorry for my English ..
    Thank you and happy to be part of this forum !!!!!
    If you want do Immo off on Fenix 5 no need any tool just 1 wire conected to eprom.
  10. #24
    MSolen's Avatar
    Dec 2009
    universe
    What you mean m8. I always use the decoder to this driver. What other way is ? can you describe it ?
  11. #25
    Junior Member beloforte's Avatar
    Nov 2009
  12. #26
    Nov 2009
    http://www.sendspace.com/pro/dl/gsv8npgotariad to know the microcontroller it already comes ready for use?
  13. #27
    treo's Avatar
    Nov 2009
    R
    Quote Originally Posted by MSolen View Post
    Solder one wire in eprom pin 22,put ignition on position 2 and triger positive impulses on pin 22 until injection lamp on instrument cluster is off,and job done.
  14. #28
    Nov 2009
    Portugal
    Hi guys.
    This immo emulator shared here by our friends is intended to work in all renault cars?
    Even Renault Space for 2003?
    I think it has edc15c2 or c3 with 3 plugs.
    Tomorrow I will order the electronic components and build one.
    After I receive the components and build one to test I will let you all know if it works or not.
    Its very easy to build.
    Regards,
    Nuno
  15. #29
    Nov 2009
    Portugal
    Anyone has schematic for the Renault immo off programmer.
    This one is very useful and if I can build it I could share with all the result, I dont have any schemas of it.
    If anyone has them please share it here and I will test it and let you know.
    Regards,
    Nuno
  16. #30
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    Quote Originally Posted by carsolution View Post
    Hi guys.
    I'm not sure about cars, but this is ecu list:
    Petrol
    SIEMENS FENIX3
    SIEMENS FENIX5
    SIEMENS SIRIUS32
    SAGEM SAFIR (55pin)
    SAGEM SAFIR2 (35pin)
    BOSCH MOTRONIC MP7.0
    MAGNETI MARELLI IAW 06R
    Diesel
    BOSCH MSA15.5 (DTI)
    BOSCH EDC15C3 (DCI)
    LUCAS DCU3R (1.9D)
    Coded fuel cut-off valve ( 1.9D DDS )
