Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
  1. #31
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Default Renault decode
    Quote Originally Posted by carsolution View Post
    Anyone has schematic for the Renault immo off programmer.
    This one is very useful and if I can build it I could share with all the result, I dont have any schemas of it.
    If anyone has them please share it here and I will test it and let you know.
    Regards,
    Nuno
    Project of Renault decoding tool,...and that info,maybe is usefull.
  2. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    mexanico1971 (1st September, 2013)
  3. #32
    argentina
    how Renault decoding tool work?
  4. #33
    Dec 2010
    Red Wine earth
    Default toyota urban cruiser
    which the tool for this car airbag off
  5. #34
    Feb 2010
    South Africa
    Does it work ?
  6. #35
    Aug 2010
    Quote Originally Posted by treo View Post
    Solder one wire in eprom pin 22,put ignition on position 2 and triger positive impulses on pin 22 until injection lamp on instrument cluster is off,and job done.
    If you want do Immo off on Fenix 5 no need any tool just 1 wire conected to eprom.
    please can you help.
    Test this someone?
    "Solder one wire in eprom pin 22,put ignition on position 2 and triger positive impulses on pin 22 until injection lamp on instrument cluster is off,and job done."
    you are shure that you must positive Impulse to Pin 22 ? and don?t cut the wire to the immo linke you must do by the Sirius ( Twingo) ?
    Thanks a lot Frank
  7. #36
    Aug 2010
    Please help, does someone have a manuel to immo off for a Renault Kangoo with Siemens Fenix5 ;; 1,4 8V Bj 1999
    Can i take this with PIN 22 ?
    Thanks a lot
  8. #37
    Top Poster + andy99's Avatar
    Aug 2009
    EUROPA
    Quote Originally Posted by MOBILTRONIC View Post
    and Hex for it?
  9. #38
    Jun 2012
    Default help for good dump ofrenault decode
    salem
    I have only atmega16l SMD.I built this quicly.Ineed help for good dump
    THANKS
  10. #39
    Feb 2011
    hello friend, sorry for my late question; can tell me someone where i find the dump for atmega16 for renault ecu decoder? and for renault immo emulator? many thanks
