Results 1 to 8 of 8
    Jan 2021
    Default Toyota urban cruiser mileage correction
    Could someone please help me correct miles to 112000 miles.
    Sep 2016
    you should upload the file..
    Jan 2021
    i used a site carhexedit but when i use their file the needles wont work on dash
    clusters's Avatar
    Mar 2015
    Canada
    Does it function properly with the old dump? When having problems, that is the first thing to try.
    Here is your file.
  5. The Following User Says Thank You to clusters For This Useful Post:
    misterwasp77 (14th August, 2021)
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by misterwasp77 View Post
    Did you saw the exact original mileage on carhexedit? I think you haven't uploaded the file swapped.
    Jan 2021
    I didnt at first. Swapped byte and it then read correctly. Done same with navara and same fault. Needles not working. It has worked on a few just not these two vehicles.
    drpeter's Avatar
    The Netherlands
    The edited adresses has nothing to do with the needles strange. I don't know what happened.
    Jan 2021
    ive done a replacement cluster with eeprom file and same. fuel gauge reading empty and needles not working again, is it these clusters cant be tampered with? needles came off very easy. the lcd fuel gauge was working fine previously
