Results 1 to 15 of 27
    Smile need help for immo off Ducati Multistrada IAW 5am
    Hello together!
    I would need your help to turn off the immo at my Ducati Multistrada 04 IAW 5AM.A0HW1031205-DU31
    Thanks,
    Tidl
    forgot the file!
  3. The Following User Says Thank You to tidl For This Useful Post:
    pintobraz (26th October, 2014)
    How did you read it???Galetto???KWP2000???Cause I have ECU without im*o,but can't read it...IAW 5AM.BS HW610
    Alex
    P.S.IAW 59M-no problem
    Smile
    Hello Alex!
    I did read it with the Galetto tool.
    You can take the dll from Fiat 59. All the same!
    The im*o for the 59 type is no prob. I know.
    But the 5am i don't find any working tool for it.
    If you could send me your file without im*o, i think i could compare it to my file.
    Thanks in advance,
    Tidl
    PM --dadatalex@hotmail.com
    Galletto 1250,1260-can't read with it some how...maybe HW103 and HW610 are different???
    59M reads No problem,but 5AM-doesn't go past data screen,if I try to read -pops "Error 4" and that it...seems like it can't go through seedkey initialization
    And Why is your damp go to #4FFF H,but my 59M goes only to # 3FFF H ???
    Alex
    Hey Alex,
    did you try with boot mode?
    There is no other way with galetto.
    I'm also not sure if the org. 5AM file is realy 320Kb !?!?
    Can you please try it in boot mode?
    Thanks,
    Tidl
    Some questions.
    How did it go?
    I understand that Galetto tool (1250 ? 1260?) can read 59M & 5AM ?
    And im*o for 59M is no problem. Using Galetto tool ?
    im*o for 5AM did you manage ?
    What about write new binfile into 59M & 5AM?
    /hn
    DK Veteran elecautocr's Avatar
    Default Im*o off for IAW59M
    I need to immo off Ducati bike with IAW59M, Do you have immo-off file for it ??
  10. #9
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    hi, i already can read flash, but how i can read eeprom 95160?
    or its possibel make immo off in flash?
  11. #10
    eep is emulated in flash, with galletto you read flash+eep
  12. #11
    DK Veteran andrym3's Avatar
    You can immo off in eep 95160
  13. #12
    Dec 2010
    There are three types of security on ducati
    External marelli box - can be deactivated in the flash
    Antenna located around the key - to allow any ignition key and any clock set to be run it can be deactivated in the flash
    The third is the ecu being locked to the bike or key . This can be deactivated in the e2p or the flash
    Locations for all the above vary from bike to bike . Took around 40 downloads and 9 hours to find location on the latest 1198. its a bitch
  14. The Following User Says Thank You to ducatisti For This Useful Post:
    Geekey (18th November, 2020)
  15. #13
    Cdoc's Avatar
    Sep 2012
    FRANCE 70
    hi
    i want make immo off on ducati 1000DS and i read iaw59AM hw610 with avdi , I do not arrive has read l eprom eep 95160, and I do not find d address in the dump of flash to make l immooff, can you help
    thank you fab
  16. #14
    Cdoc's Avatar
    Sep 2012
    FRANCE 70
    hi
    How make you to read l eprom 95160
    fab
  17. #15
    Cdoc's Avatar
    Sep 2012
    FRANCE 70
    hi
    fab
    <QUOTE=andrey3;1188260]eep is emulated in flash, with galletto you read flash+eep[/QUOTE]
