Results 1 to 9 of 9
    Default Problem with ecu reading
    i have a logan 1.5 dci 65 hp - is the same injection and engine with renault clio II 1.5 dci 65 hp EURO3.
    i've read my ecu with galleto option euro3, option euro4, kwp200+ data,readall - slow and fast
    and i i'm not able to figure out what driver to use in ecm2001 .. i;ve tried alot of renault 1.5dci drivers...
    does anywone know how to modify those items ?view the 3d inj map ? give some ideea of a program.(maybe winols does but i don't know how to use it,and i don't have a full version).
    btw i found somewhere an ecu readed by kwp - renault 1.5 dci 65hp.. and ecm driver works fine. info ecu ok...mine says info ecu not found.
    can my ecu be encripted ? how cand i decript it ? if i wrote another software on it what happens ..?
    the only good file is:
    "galleto-e4"
    There is no encryption on their files, the problem is that bad readings.
    On the other hand, does not serve any driver ecm because in order to work, drivers need to complete reading file, and galletto-e4 is a partial reading.
    you have to modify file in 2d, but I would avoid writing modficado file in that car with galleto clone.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Logan 1.5 DCI diesel (65 bhp) - use galletto 1250 (or 1260) with Delphi E4 option for Read/Write
    Use this file for test (have 84 bhp).
    Please note injectors code before you start writing (use ddt2000) and after flash write back.
    In some cases you need to Start routine - Static test in Screens XML before start engine.
    Default galletto
    heloo , do you use a galletto 1260 to read ,dump the ecu ( i have a 1.5 dci 65 hp) and i want to order a galletto interface, thanks
    your file is tuned file for a logan 1.5 dci 65 hp or original file of o 1.5 dci 85 hp?
    Default ecu ori logan 1.5 dci 65hp
    this is my ecu with settings clio 1.5 dci e4
    Top Poster + powertdi's Avatar
    Jan 2011
    Russia
    I have read it MPPS clone? Is it good file size? renault kangoo 1.5dci delphi 65hp. Is a 85hp file good for that ECU?
    Thanx in advance if somebody help.
    ALGERIA
    Quote Originally Posted by noyz2k View Post
    the dump named galleto-e4 is good and you can tuned it
    in dacia logane MCV 1.5 dci the engine have 85cv
    not the same as clio 1.5dci 60cv
    morocco
    pleasse damp for WDB 203 c180
