Hi Guys ,, please could one tell about this app ,this app use for what ?
this application is used to diagnose multiplexed systems truck cab hpv international
kaomde
Code for 884C-AC83 please.
Thanks in advance
I installed and thanks to kaomde for the key. I am using Nexiq Usb and I can't get it to connect. I made sure it was selected as the adapter. Anyone have any ideas? I can get MD32 to communicate with my adapter.
Thanks in advance
ibmman
Make sure green power led is lit when connected to truck
then make sure the nexiq adapter u selected is "nexiq technologies usb-link" sometimes there are a few nexiq entries.
if that doesnt work then try a different usb port on your pc, i know the one you have it plugged into works fine but sometimes the usb ports on a pc are assigned different com port numbers.
if that doesnt work then open rp121032.ini , it is in your c:\windows directory
it should look lke this:
[RP1210Support]
APIImplementations=NXULNK32
delete everything after "NXULNK32" if the nexiq the only adapter you are using.
Some helpfull info on adapter troubleshooting:
RapidShare: 1-CLICK Web hosting - Easy Filehosting
If all fails shoot me a pm
kaomde, can you please suply key code DLB for 42B8-CBAB and 46D4-E515. thanks in advance
hazim,
i can get most of the cards available but i asked you if u had succesfully copied a card. I'll upload 10 different cards but theres no point if it they cant be copied.
peter21,
42B8-CBAB = ABAF-96BE
46D4-E515 = AFC3-B800
thank you soo much rp1210a working great.......
