Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 65
  1. #31
    cjawahir's Avatar
    T&T
    Quote Originally Posted by AUS-MAN View Post
    You can have 7 masters and 3 valets programmed to the 3ZZ-FE.
    Next time you play with a 4C Toyota try programming in a master into a valet position and vice versa via onboard programming. Both keys will swap fine into either position.
    Like i said 4C are a very basic transponder thats why they are no longer used.
    Yes you are correct about the 4c chip , today i program a camry with a valet key from another car as a master and it work perfect . so 100% correct about the chip .
    To close the programing in the toyota corolla , with the last key switch on and off 5 times and then touch the brake 1 time .then pull the key out .
    i did all this today .
    cj
  2. #32
    Top Poster devil09's Avatar
    Quote Originally Posted by cjawahir View Post
    cj
    Dear can you tel me why i can not write or copy 4C transponder [chip type] with AD900 tool ?? it shows 8 digit eeprom code also i try with 4C glass transponder it done well. is there any difference ?? my original transponder is 4C chip type. ? if you know how to write please tell me thanks in advnce.
  3. #33
    cjawahir's Avatar
    T&T
    Quote Originally Posted by chetan View Post
    i dont have the ad900 , i dont know why , its a clone so anthing can happen ,
    i use the JMA to copy 4c to tpx1 glass chip .
    cj
  4. #34
    Australia
    I did not understand a word of that.
    Are you trying to clone a chip? or write a existing chip to an eprom?
  5. #35
    RUSSIA Kaluga
    Hello! Toyota Corolla (from the 1st post) running well !
    My problem was stupid - the amplifier of transponders (on the ign. swith) was wrong!!!
    After changing it - every is all wright!
    Thanks for a good knowledge.
  6. #36
    Australia
    Quote Originally Posted by zanovo View Post
    Glad you got it going
  7. #37
    cjawahir's Avatar
    T&T
    happy to hear that its working ,
    cj
  8. #38
    Guys first thing you should do is DIAGNOSE.
    First step is always:
    1. Check if immo sees any keys ,wrong or not.
    but im happy you sorted it out
  9. #39
    i want to copy one existing 4C key to another new 4C chip type transponder key but i didnt success with ad900 [chinese] at the same time i do with glass type 4C transponder i got success. i want know only what is correct type of transponder for copy ? any electron transponder is there for copy ? my chinses supplier told me they have eletronic circuit inside toyota key you can write any number of time i dont trust on electronic circuit instead of transponder i just want to know which transponder is correct for copy ? some 4C transponder comes with copy lock ?
  10. #40
    Australia
    You cannot write to a 4C chip.
    You can copy a 4C chip to either a TPX1 chip or Silca's EH2 head. The TPX1 chips looks just like a 4C glass chip so you are probably confusing them.
  11. #41
    Thanks mate i m very thankful to you for info please give little more info on 4C what is TPX1 glass chip ? what is texas 4C ? i want to copy 4C texas to any 4C type we just want to copy corolla key
    very much trouble here can't copy 4C texas to 4C texas
    please give me correct solution for copy 4C texas which transponder or chip i have to use for copy?????
  12. #42
    cjawahir's Avatar
    T&T
    you can copy 4c to electronic head chip , forget about the tpx 1 chip only JMA copy tool can use this chip .
    cj
  13. #43
    NOT true!
    AD900 can copy to TPX1
  14. #44
    cjawahir's Avatar
    T&T
    Quote Originally Posted by cammy25 View Post
    NOT true!
    but this is the clone and you have to install updates from advance diagnostic , plus tpx1 and tpx2 you can only get this chip from JMA company .
    cj
  15. #45
    Also not true,
    chinese sell TPX1 and TPX2 too.
