1. First prepare the sauce by combining the mayonnaise with
the dill mustard in a small bowl. Set this aside until you
are ready to use it.
2. To prepare the eggs it's best to make one at a time in a
small 6-inch skillet. If you have more than one of these small
pans, you can save a little time.
3. Beat an egg in a small bowl with a whisk until it is smooth,
but not foamy. Add a pinch of salt and pepper to the egg. Heat
a small 6-inch skillet over low heat. Add 1/4 teaspoon of butter
to the pan. When the butter has melted add the egg to the pan.
Swirl the pan so that the egg spreads evenly. As the egg begins to
cook, use a spatula to pull in a couple of the edges so that raw
egg flows from the top onto the hot pan. Cook for 2 to 3 minutes,
then fold over one of the edges of the egg using a spoon or fork.
Fold it down about an inch. Fold the opposite end over as well.
Then fold the remaining two edges over, creating a small rectangular
or square mini-omelet. Flip the little omelet over and turn off the
heat.
4. Heat up the ham in a covered dish in the microwave for 1 minute.
This will make it hot, and keep it from drying.
5. Slice a bagel in half and place it with the faces up on a baking
sheet. Grill the faces of the bagel halves in your oven, set on
broil, until golden brown. You may also use a toaster oven for this
step, but be sure to place the sliced bagel halves onto a small
baking sheet or on aluminum foil.
6. When the bagels are toasted, spread about 1/2 tablespoon of the
sauce onto the face of the top bagel half.
7. Place a slice of cheese onto the face of each bagel half.
8. Place the finished omelet onto the cheese on the bottom half of
the sandwich.
9. Place the ham onto the egg.
10. Finish by flipping the top half of the sandwich over onto the
bottom. Heat for 15 seconds in microwave if needed to warm.
Makes 4 servings.
