Results 1 to 9 of 9
    Jul 2010
    UK
    Default KSuite 2.80 software - Full Help & Protocols
    KSuite 2.80 is essentially the same as 2.25/2.47.
    Same protocols, just better error correction and "supports more cars" which essentially means it lists more cars which use the same protocol/ECU as the older versions of the software, and you can use it with Kess and Ktag.
    • Full help included in 6 languages; English, Spanish, German, Portuguese, Italian and French.
    • Full DLL protocols, 134 total.
    • Supports both Kess v5.017 and Ktag v7.020.
    There may be a false positive detected form certain antivirus programs.
    What you do with the software is up to you, I take no responsibility for anything you choose to do with it.
    All the information you need is in the link blow.
    Thanks and Rep appreciated.
  2. The Following 49 Users Say Thank You to johnnybeast For This Useful Post:
    1971 (28th December, 2021), Adiadi (2nd December, 2023), AIDIN R O (30th October, 2021), alessioblaupunkt (8th February, 2022), arabikx0 (31st December, 2023), Bolino08c (18th December, 2022), busu (29th October, 2021), CasaEd (3rd March, 2022), Cherchy (20th December, 2021), djd_lases (5th December, 2021), Dxstinb (21st November, 2023), esse (4th April, 2024), ExpatMat (28th January, 2024), exxter (16th November, 2021), feranaeletrica (22nd November, 2023), frappes (28th May, 2022), genhack23 (14th December, 2023), gtr101 (17th February, 2022), installcar (11th November, 2021), jay7 (20th November, 2023), KCSS (13th October, 2023), LexLuth (4th June, 2023), ljamert (12th October, 2023), llcalin (15th November, 2021), madbg (15th November, 2021), MarcAlfonso (26th March, 2024), maskot83 (24th April, 2024), miloudmess (29th October, 2021), mishka45 (6th October, 2023), motor race auto (19th May, 2022), NORSHAN (27th January, 2023), oenn (9th November, 2021), orx (29th June, 2023), p38 (30th December, 2021), pablodelhierro (1st January, 2022), PaoloDigital (2nd January, 2022), peppearci (14th March, 2022), Phnman390 (7th May, 2022), popflaviu (5th December, 2022), POWERIVAN (26th November, 2021), pupiilov (2nd November, 2021), radiorepair (1st December, 2021), skyline32 (2nd January, 2024), Solafe89 (19th January, 2024), StevenKA (18th April, 2024), taedla01 (14th September, 2022), Troco5773 (8th July, 2023), unique user (10th December, 2021), ZondaHivic (18th September, 2023)
  3. #2
    Jun 2015
    Question: Ktag v7.020; do you need to reset tokens with this version?
    Jul 2010
    UK
    The software doesn't control the token limits of the hardware, the token reset is down to the hardware (SD card / Firmware).
    This software will update the protocols for the KTag, but it doesn't allow the KTag to be used in conjunction with the 2.80 software. You will need to update the protocols using 2.80, then use 2.25 to be able to program using KTag more reliably.
    J.
  5. The Following 2 Users Say Thank You to johnnybeast For This Useful Post:
    alessioblaupunkt (8th February, 2022), p38 (3rd January, 2022)
  6. #4
    Jun 2015
    Ktag v7.020 chinese clon, on the board version 2.25
    I won't be able to use version 2.80?
    You only recommend installing version 2.80 to update the protocols in KTag? And then installing 2.25 and using this older version?
    Won't the newer version block KTag?
  7. #5
    Jul 2010
    UK
    No, you won't be able to use 2.80 with Ktag.
    I do, it will be more stable with the newer update.
    It shouldn't do.
  8. The Following 3 Users Say Thank You to johnnybeast For This Useful Post:
    alessioblaupunkt (8th February, 2022), orx (29th June, 2023), p38 (3rd January, 2022)
  9. #6
    Nov 2023
    can i use this software in my kessv2 5.017 red pcb eu? newbie kess user
  10. #7
    Mar 2020
    thank you!!!
  11. #8
    Jan 2019
    Lisboa, Portugal
    Thank you.
  12. #9
    Dec 2022
    Thank you !!!
