Results 16 to 30 of 39
  1. #16
    Jun 2013
    ROMANIA
    SOMEONE HAS CONNECTION XPROGM ADAPTER BDM HCS12 TO THIS CPU??? XTAL PIN MUST BE CONECTED??
    FLASH NOT WRITE... EEPROM YES...
    IS XPROG M 5.0...
    WITH 5.51 TEST SOMEON???
    UPAUSB READ/ WRITE FLASH OR JUST EEPROM?
    PLS HELP...
    THX!!!
    SOMEONE HAS TO CONNECTION WITH CPU adapted to XPROGMSOMEONE HAS TO CONNECTION WITH CPU adapted to XPROGM
  2. #17
    Jun 2013
    ROMANIA
    software bgcomp
    80 tested by my...work 100% OK... GOOD JOB!!
    THX!!
  3. #18
    Jul 2016
    I'm new to this forum, but not new to Allroad's...
    I've seen several of these controllerd fail with the 65535 memory error code.
    And I have a buch of these.
    After what I see here, there are a possibility to gove the controller "new" life"?
    Can any one confirm this, and maybe even give an old Viking an explanation of the procedure?
    Thanks,
    -Roy
  4. #19
    Dufner
    Johnner's Avatar
    Éire
    Roy,please go introduce yourself here : Introduce Yourself
    Thank you... and welcome to Kaos...
  5. #20
    no need change eep and Flash
    only repair file
    i have solution Thanks+Reputation please and info by PM
  6. The Following 13 Users Say Thank You to garageozcar For This Useful Post:
    alclot (7th July, 2021), Cic2000 (3rd February, 2019), ctcgorzow (3rd January, 2017), cveti72 (4th November, 2017), kukukatsu (17th July, 2017), panderetamix (19th September, 2016), Razius (30th December, 2021), seba_m_ (4th December, 2016), smart0187 (29th November, 2018), Telectroboy (15th September, 2020), tojlp (16th March, 2020), Trumps (20th April, 2017), TurboR (28th June, 2017)
  7. #21
    Dec 2017
    Thanks for share ... Now I have to buy programmer and try to mend controller up ;-)
  8. #22
    Sep 2016
    someone knows why I can not download these files?
  9. #23
    Mar 2018
    Hi,...
    Can garageozcar please contact me via PM. Your PM-box is full. I have UPA-USB and cant write flash, just eeprom. Any suggestion would help.
    Thank you and BR
    Cic
  10. #24
    Mar 2018
    Problem solved with X-PROG...
    BR
    Cic
  11. #25
    Sep 2020
    thanks for the file! great job
  12. #26
    Sep 2020
    Hello guys!
    I have the same problem with an Audi AllRoad. I have few tools to read and write even Xprog.
    I hope to be able to solve it thanks to your help [Crossing fingers]
    Thanks a lot. I'll tell you the result.
  13. #27
    Sep 2020
    Hello Guys!
    This is the values of EEPROM I have read with Xprog...
    What do you think about that?
    The module doesn't work and display 65535 in VAGCOM.
    Thanks alot.
  14. #28
    Jan 2018
    I will have to fix an audi a6 suspension control unit 4Z7907553A but I have XC5113c1cfu8 processors
    do you have solutions?
  15. #29
    Nov 2016
    I have same issues (error in memory) with module 4Z7 907 553 F.
    I have "A" module from a friend, it is as mentioned with different microcontrollers.
    I ve tested it, but got an error with controll buttons as far as i press some.
    Seems like the "A" module is incomplatible with "F" , unless you reprogram it!.
    I need files for "F" module, but the link on previous page is down. Can someone share the files again?
    EDIT: LINKS WORK, BUT FILE GOT DOWNLOADED AS 4Z7 907 553 F.rar.zip
    Solution: Simply delete .zip from the name of the file.
  16. #30
    Jul 2016
    How did this turn out for you?
    I have several ECU's to reprogram...
