Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Default Audi A6 allroad 2002 level control
    Hello.
    Audi A6 allroad 2002. Level control unit 4Z7 907 553 E has permanent fault "65535 - Internal Control Module Memory Error". There is MC68HC912D60 0K75F inside.
    Has anybody full flash for this unit?
    Enclosed is eeprom and seems to be correct.
    Thanks.
    Does somebody have such flash?
    hello my friend
    can you tell me where that dump belongs to ?
    is it from the xc68hc912 controler? which one ..... the one thats in the uppside or downside?
    next to the mc68hc912 in the top side there?s a 8 pin ci TFK28730 that seems to be an external eeprom of the motorola mcu. anybody knows if this is correct? if yes does anybody has a dump for it and wich eeprom it should be?
    i would be gratefull.
    Hello.
    Both Motorola CPUs (upside/downside) are used. Each of them contains own internal eeprom (not external). Sorry, I don't have good dumps for these processors.
    hello everybody....
    has anyone have good dumps for these MCU?s?
    it seems that one is for ESP and the other is for Suspension.
    hxxp://www.volkspage.net/technik/ssp/ssp/SSP_242.pdf
    tintin2005
    Feb 2011
    Hello.
    My Audi A6 allroad 2001. Level control unit 4Z7 907 553 A has permanent fault "65535 - Internal Control Module Memory Error"
    I find Level control unit 4Z7 907 553 E but i don't no it is compatible?
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by bizu View Post
    Hello.
    If you put in both the *** *** 553A and *** *** 553E parts number you get the message:
    "dropped on 01/07/2004, please use as replacement"
    427 907 553F
    So your 553E ill do the same job as the 553A
    i know how to repair this unit
    contact me on PM
    Jan 2011
    Romania
    Your PM is full, maybe you can give me a hint on where to start .
    Jan 2011
    Romania
    There are two MCU`s XC68HC912D60, one on front side and the other on the rear side .
    You can repair the suspension module by writing the flash and the eeprom in both MCU`s.
    I attached the last software 4Z7 907 553 F .
    The module used was 4Z7 907 553 A and now works with 4Z7 907 553 F software and works perfect .
    Enjoy .
  11. The Following 32 Users Say Thank You to bgcomp80 For This Useful Post:
    aksimo (10th February, 2016), alclot (7th July, 2021), alex91 (8th October, 2020), Anydraj (11th August, 2016), bkjbig (7th January, 2016), bokilee (8th October, 2015), ccyberwing (29th July, 2016), Cic2000 (3rd February, 2019), diga1 (1st November, 2015), ekas (13th April, 2016), epicsabi (13th May, 2022), gelencserg (7th March, 2018), HeXeN (8th July, 2020), ionuty (20th July, 2016), jovial (6th July, 2016), joze (30th August, 2018), jupulino (11th March, 2015), kukukatsu (17th July, 2017), LuisBand (11th August, 2016), mioiox (13th June, 2018), PETERALC506 (14th August, 2015), Pups12345 (6th January, 2023), rikitech (14th July, 2017), sdade86 (16th November, 2022), SebaGTC (17th August, 2023), Sziri (14th October, 2021), Telectroboy (15th September, 2020), Truan21 (7th February, 2018), Trumps (20th April, 2017), xifly18 (24th February, 2015), xseva (7th July, 2022)
  12. #11
    hi thanxs for sharing but i hope you can help me or someone
    I?m trying to write flash with xprog-m but without success, i always have error while verifying
    Any ideas, i write eprom without any problems, R/Verify, but not the flash...
    Any help appreciated
    Br Pedro
  13. #12
    Finland
    You need to put +12V to pin 71 in qfp80 processor, then you can operate flash.
  14. #13
    Scandinavia
    Default battery drain 4Z7907553E
    Does anyone know reason why some of this ecus cause battery drain?
  15. #14
    Portugal
    How did you read this processor???
    I can read with UPA but just one of them. I use xprog, etl and rosfar but none of them can comunicate.
    BR
  16. #15
    Nov 2011
    Thanks for share ...
