Results 1 to 7 of 7
Thread: DPF Remover
    Aug 2021
    Default DPF Remover
    I have a question. I installed "Professional DPF Remover" but the software does not launch.
    anyone know how I can get it to work? anybody that can do 1 DPF delete for me, I have oem file.
    Car is Land Rover Discovery 2009 2.7 TDV6.
    Greetings
    Sep 2021
    Send your orig file i'll try to remove your DPF if i have time today.
    Try excluding the installation path from windows defender and any other anti-virus software. Also what windows version are you using?
    Hopefully this helps.
  3. The Following User Says Thank You to kubaK For This Useful Post:
    ems5139 (12th November, 2021)
    Aug 2021
    windows 10 pro build 19042.1348 all antivirus is disabled, "Professional EGR Delete" does work, Thanks for the offer but I got someone else to delete DPF.
    dehacko's Avatar
    Feb 2018
    SK
    windou xp is best for remover
    Aug 2021
    i'm going to try tomorrow on windows 7/XP
    fuzz1's Avatar
    Jul 2019
    Try with virtual box
    Sep 2021
    Quote Originally Posted by fuzz1 View Post
    Some modification to the actual virtual box will need to be made as DPF Remover will not run on a VM instance. If i remember correctly.
    If i helped you don't forget to thanks & rep
