Results 1 to 8 of 8
    sdnatlst's Avatar
    Aug 2011
    England
    Default honda 37820-PHK-G21 ecu - is this immo board? 2001 CIVIC
    can i just move this immo board to replacement ECU to start car?
    can i just move the eeprom on board, or need whole board?
    thanks in advance!
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
    rafal's Avatar
    Jul 2010
    UK - PL
    immo in eeprom..................
    remove board = immo off
    fill FF in eeprom = off
    with off - MIL will on
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    sdnatlst (24th November, 2021)
    sdnatlst's Avatar
    Aug 2011
    England
    Thanks RAFAL, ill swap the eeprom to the replacement ECU then!
    Tools owned -
    fuzz1's Avatar
    Jul 2019
    Just want to know if someone tried ff fill of the eeprom. Does the car run normally or will go in limp mode with mil light on.
  6. #5
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    check if its automatic too,if so,it will have some issues
    If i Helped you,use thanks and rep button to thank me back
  7. The Following User Says Thank You to Stelaras26 For This Useful Post:
    fuzz1 (3rd July, 2022)
  8. #6
    fuzz1's Avatar
    Jul 2019
    Yes automatic. Is there anyway to get around those issues? Don't want to touch the original ECU to avoid any possible problem with the owner
  9. #7
    Mar 2020
    hello masters
    i need your help
    i have an ecu from Honda CR-V, 37820-PNB-R01,with manual transmition.
    I have read the eeprom from ecu and from immo box and I would like from someone to synchronise them to start the car.
    In attach include the eeprom from eng ecu and from immobox
    Regards !!!
  10. The Following User Says Thank You to ecu fanis For This Useful Post:
    speedservice (5th July, 2022)
  11. #8
    Mar 2024
    thanks for the archive
