Results 1 to 10 of 10
    Dec 2021
    Default ECU blocked?? by read with KESS. Opel Astra G Delco MT35 2ZZSE
    I was reading the ECU by KESSv2.
    At 98% load the KESS freezed and disconnected from ECU.
    Car don’t start and don’t connect again.
    can someone help, what I have to do now ? What tool to by? Only have KESS yet
    OPEL DELCO Z22SE HW 12586913 XD
    Version HW 01000371
    SW DEL 011A16265590
    Motor Z22SE
    VIN WOLOTGF674B001075
    mersytis's Avatar
    Jul 2017
    Quote Originally Posted by abyn0t View Post
    Version HW 01000371
    SW DEL 011A16265590
    Motor Z22SE
    Did you try to write? Did you try to read again?
  3. The Following User Says Thank You to mersytis For This Useful Post:
    abyn0t (10th December, 2021)
    Dec 2021
    I try it again after battery off. Engine start and Ecu read.
    How I can write the flashed file.
    Do I need Immo off or Car Pin to write mapped Ecu ?
    mersytis's Avatar
    Jul 2017
    First you need to read flash 100%. You can upload a flash and I'll tell you if it's a good readed. If you write with Kess immo will be unchanged. And use a charger when writing!
  6. The Following User Says Thank You to mersytis For This Useful Post:
    Dec 2021
    Useful infomation !! I send you the .Ori File and an "Mapped Stage1" that i get at a german from Forum
    Files are 512KB
  8. #6
    mersytis's Avatar
    Jul 2017
    Files are 512KB
    Do not attempt to write this file! I compared they are very different. Probably a different version. Read Kess ID and write info (sw version and etc.)
  9. #7
    Smart66's Avatar
    Dec 2020
    I think you should make FULL backup before writing
  10. The Following User Says Thank You to Smart66 For This Useful Post:
  11. #8
    Dec 2021
    What do you mean FULL Backup? .ori file is 512KB
  12. #9
    mersytis's Avatar
    Jul 2017
    Full backup can be done with Ktag. File size is same full and not full.
  13. #10
    Jul 2018
    Read with Ktag, then search for a file that has same ID as the one u read with Kess....compare ktag file with the on u got from search,
