RENAULT CAN CLIP REPAIR SOLUTION - Page 3
Page 3 of 45 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 674
  1. #31
    Jun 2009
    salut a tout tr?s bon sujet
  2. #32
    some know any idea?
  3. #33
    DK Veteran BeianM's Avatar
    Dorset UK
    Quote Originally Posted by Joe019 View Post
    some know any idea?
    About what?
    Please state your problem so we can help you. Or click on the 'quote' button to include someone elses question that has not been answered.
  4. #34
    Hi BeianM.
    thanks for try to help me
    My problem is that sometimes the CLIP cant caught VIN automaticaly ( in cars when possible caught VIN automaticaly ) and sometimes cant enter in diag mode. We try with other CLIP and same car, and goes well.
    In the failed CLIP the ISO and the CAN led green is lighting.
    It fails lot of times, and dometimes go well. I tryed with a new USB cable and same...
    This is a ORIGINAL clip ( not clone from china ).
    Thanks in advance.
    My best Regards
  5. #35
    Dorset UK
    sometimes the CLIP cant caught VIN automaticaly and sometimes cant enter in diag mode.
    I have read that even original clip sometimes will not read the vin no. You should continuity test the cable end. Unscrew it from the main body & check that the cable to circuit board is ok. The connectors are not good quality. Maybe you can swap parts from one clip to another to prove if one is faulty.
    Please try & let us know how it works out.
  6. #36
    Thanks BeiaN
    I am going to test this day.
    I will report you news.
    My best Regards
  7. #37
    ITALY
    now has a problem, when I plug the obd socket and then the usb, I hear two "clicks" usb device connected to a PC and not 4 as the first .... of course the software does not see the probe. any ideas?
  8. #38
    Dorset UK
    Default clip no probe
    Quote Originally Posted by morfeo View Post
    I would suspect a poor connection of the probe to the clip. I have had this & a disconnect/reconnect fixed it.
  9. #39
    I resolder the PCB and now clip works mutch better!!
    Thanks!
  10. #40
    Default renault clip fix
    i have three boken clips sent to me by third party have two good cypress chips swapped to the three units all had no iso and can light.
    all three units came back to life iso light now on and can light on
    only prob is software wont update not your problem
    my question to you all is i can get cypress chips but there is a minimum order of 20 and there ?25 each if i get them and put detail instuctions on how to swap(you need hot air soldering gun for maplins ?32) and put on e bay would any one be intrested.
    i know that this cypress chip problem is common and if i can swap these chips any one can
    let me konw
    iain
  11. #41
    Quote Originally Posted by rtvservis View Post
    vhen you have problem with clip iso or can grin led dont work .
    usb dont recognise can or iso driver you have demage ic AN2135SC it is usb 4 hub. you cen bay hear Herzlich Willkommen bei Braintechnology Logicanalyzer, USB
    hi rtvservis
    i changed an2135sc ic but no change problem.i want to question when change ab2135sc must i load fimware?
  12. #42
    Member aitistu's Avatar
    Timisoara, Romania
    Default original broken clip
    hi everyone
    i have an original clip from 2002 i think, the laptop hdd broke down, but that day the sonda was fully functional.the laptop was old and had win98 on it so:
    i installed same clip software from original cd on another laptop with xp using the clip.reg trick from this forum (thanks DK) because on original laptop with another hdd and win98 the software asks for registration and the original vendor doesnt exsist anymore (i dont know where to ask for a reg code )
    when i connect the usb from the sonda to the laptop it only asks for 2 drivers and then silence..
    i am sure that the sonda is ok , because the only thing i did was to conect it to usb after conecting it to the car..
    in device manager i only have the devices discovered, diaghub and diag usb something...
    the sonda and software is original, the sonda doesnt have any leds so i dont know what is discovered and what is not
    the four .sys files are in my c:\windows\system32\drivers
    any ideas where to start?
    c
  13. #43
    hello,
    you have the old interface, i have this too. You need clip V74 because this is the last version whitch work with diaghub and diagcom. search in automotive software section, hope it will help you!
    good luck!
  14. #44
    Hi m8, yeah send me a AM, I'm off to bed now. Don't use MSN that much.
  15. #45
    Newbie cosmindaniel's Avatar
    romania
    Hy; i have a Renault Laguna 1v2 facelift from 1999 year; i need to know how can i connect with my car and what software what i need??? I have a DDT2000 vers.2.0.9.0 and from what i observe in this forum my cable isn't for this car or software. It's VAG 409.1 !?! I don't no how can i connect to the car.Who know???
    Please help me because i try to found a software about 2 years.
    Thank's in advance.
