ok thanks for answer
Hi all have anyboda solution for peripherall disconecting ( Alliance with Bluetooth )??
if exists, until today I haven't found one, so if you can send it back to the seller asap.
China sallers not going to fix it, do not waste your time. I also have same thing with two clips, disconnecting time to time. PCB is the same like Consult 3. My friend got the same clip with the same board and no problem with disconnecting.
I was lurking the l04a's datasheets and I think that I saw something like 16V Vmax input. did somebody already tried to put a 7815 on the Vin as safeguard for those ocasions like starting the engine with clip attached?
That`s no software problem and drivers for sure. You can connect just power supply, and usb to PC (without software runing). Any way if no action is taken after about 20 minuts green led blinking and bluetooth starts.
You don`t have to be connected to the car to get disconnet for a moment.
Some fixes: http://obd2-diag.blogspot.com/p/renault-can-clip.html
Greetings!
I have a SP19-B copy and everything is fine with it except one thing: it keeps disconnecting and reconnecting randomly. The first thing I wanted to do is the DPF regeneration on a Laguna ph2 but as it disconnected and reconnected, the Clip did not provide live datas anymore. Moreover, the DPF regeneration program did not end even after 1 hours. I use it with V164 Clip and also tried the 130 version with no luck .
So the question is: Why does it disconnect?
I hope you can help me
thanks to all for sharing
i change the quartz on ISO board the red led not work
can you help me
best regards
My clip broke because of cable problem (disconnected during software update).
The problem was corrupted flash on ISO board (missing some software).
I downloaded ISO board flash dump from this site, flash but still I have problem. Software update fail, but when I remove appliiso.s19 lip works fine (I can do full diagnostic on my car).
Any idea what should I do. Maybe different dump?
Me have bought 3 consult from
http://www.ufodiag.com/
all is crap lose conection all time one me broke apart two send back to fix then one lost in post
one they fixed got back same crap not vorking then they told me have high quality canclip
vork good tested vorked one car nov iso light go off this chinese sell only garbage they fix nothing
always they say fix ask enginer and dont knov vhat so at end you get tired.
heloo image ush megane 2
My Can Clip have same problem. Change 74 % and....error message- "Failure of the reservation of the probe. Try it again and contact technical assistance in case of another failure? . What is the final solution ?? THANKSSSSSSSSSSSS
My Can Clip have same problem. Change 74 % and....error message- "Failure of the reservation of the probe. Try it again and contact technical assistance in case of another failure? . What is the final solution ?? Any help ??? Thankssssssssssssssssssssssssssssssss
tray Renault can clip solutions http://obd2-diag.blogspot.com/p/renault-can-clip.html
sergei5005 (24th December, 2017)
