You can use dump from your "old" flash chip, anyway it must be programmed before going back on PCB,
I think that those dumps are already posted somewhere in board.
Regards!
Regards!
Good evening,
I have a CANCLIP probe, my four LEDS is lit(switched on)
But impossible to be entered diagnosis, bloquage on update firmware 20 %. And loss of communication and to verify food(supply).
What is are them constituent(component) to be replaced (if possible in photo?)
Thank you
I install version 131 clip good but after a few days for opening software give me Error 15024 and 15028
What is problem ?
i check Interfaces = Good .
LED Interfaces = Good (Green and Red) .
Cable: USB & Prob = Good.
install again software = but not solved problem.
Please help me. it now can't connect to car.
Thanks.
hi
I have a CAN clip,
I do not detect modules, he says low battery
I start the engine and if I reconose all modules
you can help me that is?
greeting
I was a ISO led problem, and i solved making a jumper in MCU 1 and 132 pin to send the signal on to the rest of ICs.
ISO board start now but 20% firmware error. Before this I see in Strobe pin of LM311 I have 12v is that correct? I remove the IC and test in board and 0V IC pins there is no short circuited. is LM311 faulty?
Welcome.
I also caught up with green LED fault ISO disabled.
what is already done:
Replacing AN2135
Replacing the oscillator 32768khz
Improving connections
HOT-AIR heating
but the green led ISO off, the program does not see the probe.
You can help give you some ideas on what else can I do?
Thanks in advance for any help.
Check that big protection diode.... and check if you have than powersupplys on ISO board.
titoun (7th November, 2014)
hi friends
i have always message about clip interface deconexion
anybody have this message also ?
Hi friends
my clip lose communication lot of times, during scaning DTC
i doubt about quartz, but maybe anybody know and solve this trouble
thank you
eudin77 (4th January, 2015)
Full Flash AM29F800BT for ISO and CAN block . Read today , before my clip ISO light off ..... add two eeprom ...
Chesterr (3rd April, 2019), Ginocar (26th March, 2016), habbou (8th January, 2016), hbalazs (23rd February, 2016), jackeldestripador (23rd July, 2019), JareckiPL (23rd December, 2018), juanes 3 (15th April, 2020), klonone (29th March, 2019), samyy (10th September, 2016), scorpioman (18th August, 2023), Subix (3rd November, 2020), visio (18th September, 2017), ziomski (13th October, 2019)
hi,
i have clip 96 clone, and want to upgrade. any sugestions for which version are welcome
thank you
regards,
c
Вирішено! Led ISO На ..... 3 дня перевіряються всі компоненти ....: Відскік: Best Regards !
asliyucegsm (30th November, 2017), brodaty (17th November, 2015), Ginocar (26th March, 2016), hbalazs (23rd February, 2016), Inycar (8th October, 2018), Jashmine1983 (2nd January, 2016), juanes 3 (15th April, 2020), KennySmit (5th August, 2018), mexanico1971 (8th May, 2014), samyy (9th September, 2016), sapopt (27th May, 2017), scorpioman (18th August, 2023), visio (18th September, 2017)
[Quote = andkl2810; 2266313] Вирішено! Liderados ISO На ..... 3 дня перевіряються всі компоненти ....: Відскік: Saludos [/ quote] hi ?
hi
What is the malfunctioning of this resistance?
greeting
