Page 41 of 45 FirstFirst ... 3136373839404142434445 LastLast
Results 601 to 615 of 674
  1. #601
    Oct 2016
    i also had problem with my rlt2002probe and i ve solved it with help found in this forum. my problem was the green led on iso pcb who didn't turn on and i've changed the oscillator from an old pc motherboard and now it works. thanks a lot guys! sorry for my english!
  2. #602
    Nov 2016
    I have a can clip that has all indicator LEDs on and reads the vin (Laguna 2) but then comes with warning Battery low and does not indicate the network although i have constant 13.8 Volts on the system, I think it is a common problem but I dont find any solution
  3. #603
    Hello!
    I don't have the clip but I have the vallise tester and almost all the cables. I need the clipper for measuring current (Amperes).
    Does anybody know witch is the last CLIP version for the Sagem valise tester? The only I have successfully installed is the v50 for sagem. I tried the v68 but it don't work with Sagem, it is for other brand but I don't recall witch is...
  4. #604
    Jan 2017
    I'm looking for an old version of can clip (v49, V54,55,56), can someone share it again, please?
    All the links I found are dead
    I changed the AN2135SC on a very old can clip clone, now the 4 led are on, but It seems I need a firmware downgrade.
    Thanks a lot
  5. #605
    Apr 2012
    ı need very urgent cy7c65113c dump file..
    any body have please need file..
    ı try make a backup beeprog always gıve errror
    readıng devıce errror device protectıon ıs set..
    or whı knows how open protectıon
    please help...
    best regards
    diagnostamir
  6. #606
    Feb 2017
    I have a CAN CLIP model CHIP 926573, after to make an instalation it doesn?t work a ISO green light when it connect to the car. So i trying to install in other computer but it continues no working. Anybody knows any solution for this ?
    I give a litle photos to see the problem. Thank you.
  7. #607
    Check oscilator quartz on Iso board
  8. #608
    DK Veteran bobbik's Avatar
    EUROPE
    My Clip first stopped work Can LOW , after some time it doesn't work at all. It says BIOS 1 error?
  9. #609
    Jan 2013
    italy
    hi folks
    I have this sp19-b altera 926573 that gave me random lost communication errors at first, then stopped working completely. when connected to the car there isn't any leds activity, no relays click, no usb connection, completely dead.
    using an external power supply there is a small spark so there's something happening (no fuse blown so until now so I guess it's not shorted), but visual inspection didn't revealed anything. zener diodes looks ok, fuses pass continuity test, did some rework even if everything was already apparently without continuity problems, and measuring the voltage on the board there is some juice.
    somewhere I read about replacement of oscillators and chip, but in my case the pcb layout it's different. plus I can't identify my oscillators' value (r143pac8?)...
    interface photos: http://imgur.com/a/9gVRN
    any idea?
    thanks in advance
    edit: send it to cina for repair.
  10. #610
    Jan 2013
    italy
    bought as replacement what looks to be a sp19-c model, with an2131qc hoping to don't encounter the 2135's problems.
    for my fortune this is a DOA, the pc recognise it, installs it with three drivers (one generic hub usb, one iso and one can). but when the can clip tries to read the vin, the green lights goes off, first from iso (the board with the usb), then from can.
    replaced the 32k oscillator from the iso, then on the can. I did some hot air rework, but the problem remains.
    what should I do, replace the 2131 or look for something else? the problem is that I don't have/know to use a programmer for the 29f800.
    PS: the strange thing is that the red light from the iso gets brighter only when plugged to the usb, and when connected to the car the relays seems to be too silent (desoldered and tested them and are ok)
    PS2: anyone from italy?
  11. #611
    morfej's Avatar
    Quote Originally Posted by diagnostamir View Post
    please help...
    best regards
    diagnostamir
    Replace it with CY7C65110 ... as it does not need to be programmed.
  12. #612
    Top Poster + jimthejock's Avatar
    Scotland
    Hi my clip which I havent used in a long time is now looking for an authorisation code can anyone help me
    Jimmy
  13. #613
    Nov 2015
    i have problem with RLT2002 original probe
    not have ISO LED light
    2 RED LED ok , 1 green LED ok
    anyone have solution for this ?
    I've already swap the 32768 khz oscillator, but still no luck
  14. #614
    ecumix's Avatar
    Apr 2014
    Hi i have question i need update my clip from v127 to v165 so i have question i must need change my hardware?
  15. #615
    recently updated from v143 to v164, never even asked for a firmware update
  16. The Following User Says Thank You to autotrans For This Useful Post:
    ecumix (21st March, 2017)
