Page 8 of 45 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 674
  1. #106
    Junior Member bo0st's Avatar
    Quote Originally Posted by dijo View Post
    Yes, please reupload it, for me it is not possible...
    Winrar, Winzip, 7zip nothing works...
    please. only for you
  2. The Following User Says Thank You to bo0st For This Useful Post:
    mexanico1971 (31st March, 2013)
  3. #107
    amir_82013's Avatar
    This file to repair hardware device
    Whether to repair the program (software) will be working?
  4. #108
    Thanl you boost, for uploading it again, but the file is also not working for me. WinRAR and Winzip says that file is damaged (file size with 2.62MB is OK)...
    Can you or someone else upload it with winRAR compressed please ?
    Best Regrds,
    Eddi
  5. #109
    jacm3
    Guest
    Thanks bo0st, for to share this files!!!
  6. #110
    DK Veteran BeianM's Avatar
    Dorset UK
    I see some have unzip problems with this file. There appears to be a corrupt file within the folder perhaps this is the problem. Please see the image below. Perhaps you could tell us what "new file~" is? Cheers.
  7. #111
    maybe this is the problem. can you upload it new packed without the bad file ?
    BR
    Eddi
  8. #112
    Quote Originally Posted by BeianM View Post
    dont think this is the problem but new package added
  9. The Following User Says Thank You to bo0st For This Useful Post:
    samyy (25th August, 2017)
  10. #113
    Thank you boost, now i can open it.
    Do you maybe have a link to v55 for flashing ?
    BR
    Eddi
  11. #114
    Quote Originally Posted by amir_82013 View Post
    hi
    I need version 85 clip for download.
    Please help
    CLIP V85.txt
    here can clip V85 good luck
  12. #115
    Quote Originally Posted by bo0st View Post
    so boys!
    after 2months is my CAN clip repaired! was broken after starting with broken starter (voltage spike).
    at first you must repair power line. next to repair power supply. and last step is flashing the tool with ver.55 CLIP software.
    generally dont use chinese clone with low battery or broken starter/alternator.
    files and photos coming soon!
    link can clip v55 pleasure
  13. #116
    Quote Originally Posted by cavignac View Post
    sorry have lot of work. please stand by i must upload somewhere.
  14. #117
    dijo's Avatar
    I don?t now if everybody here solved the extract problem...?
    Now for me it is OK.
    I rename the extract file with the extension .zip and extract it again... This was the way for me...
    hope this help anyone if he can?t extract the file...
  15. #118
    Default Impossible to read
    Hi!!!!!
    I can't open this file which interst me much..... Winrar always says it is corrupt.......
  16. #119
    Alpes in french
    I have a question for you
    First, thanks for your post ;-)
    I have a clone clip and i have use it one month but last time it isn't reconise on clip software... >> ISO GREEN/RED is off
    I have search LT1766 and find it on "2.JPG" PCB or POWER DIODE LINE is on "1.JPG" PCB it's correctly ?
    But on pin 10 I have 5.11V ....
    Have you an over idea ?
    Best regard Alain
  17. #120
    dijo's Avatar
    Quote Originally Posted by vieuxchoub View Post
    Hi!!!!!
    M8 when you read you find the solution, only one before yours...
